pBe Posted December 21, 2011 Posted December 21, 2011 (edited) Same question as above...hot to set that point?? Flopo, if you run (_LowYcoord pointList) where any of the variables (sym) included on pointList evaluates to nil the result will be nil and not a point list. Make sure those vairables is a valid point list what you can do is (defun _LowYcoord (pointList) (car (vl-sort (vl-remove-if 'null (mapcar 'eval pointList)) '(lambda (a b) (< (cadr a) (cadr b))) ) ) ) that way you can maintain this line (setq pMin (_LowYcoord pointList)) and not rebuilding the list everytime to include only valid variables (setq pointList '(J1 J2 J3 J4)) (setq pointList '(J10 J11 J23 J4)) Edited December 21, 2011 by pBe Quote
flopo Posted December 21, 2011 Author Posted December 21, 2011 Now is working!!! Thanks Pbe! Thanks guys! Quote
pBe Posted December 21, 2011 Posted December 21, 2011 Now is working!!! Thanks Pbe! Thanks guys! Right on. kudos to the rest of the guys , they did all the work Quote
