alanjt Posted June 22, 2011 Share Posted June 22, 2011 Just as a side-line suggestion: wouldn't it be "better" to have such a thing run as a login script? Though even then I'd add some form of check before deleting, since others may already have the DWGs open before you login. I want it to activate upon each drawing being opened. That way it cleans all the random crap files out of the directory. We've been using this for quite some time, and we'll have everyone in the office working in drawings from the same directory and have NEVER had a problem. If a dwl or dwl2 is part of an active drawing (you or anyone else has it open), it's considered read-only and vl-file-delete just nils and moves on. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 22, 2011 Share Posted June 22, 2011 Where is your code alanjt? I could use that. Quote Link to comment Share on other sites More sharing options...
alanjt Posted June 22, 2011 Share Posted June 22, 2011 Where is your code alanjt? I could use that. ; cleanup drawing directory ((lambda (path) (or (wcmatch (getvar 'dwgname) "Drawing*") (foreach file (vl-directory-files path nil 1) (if (wcmatch (strcase file) "*.LOG,*.ERR,*.DWL,*.DWL2") (vl-file-delete (strcat path file)) ) ) ) ) (getvar 'dwgprefix) ) Quote Link to comment Share on other sites More sharing options...
Ahankhah Posted June 22, 2011 Author Share Posted June 22, 2011 I hope your routine doesn't simply delete all of them! Since then you'll get the UnknownReadonly returned by my function. Are you sure? When dwg is read only, dwl is also not eraseable:wink:. Quote Link to comment Share on other sites More sharing options...
Ahankhah Posted June 22, 2011 Author Share Posted June 22, 2011 For this I'd advise Ahankhah to rather put the close call as close as possible to the open - I'd actually place it directly after the open inside each cond condition. Even though you then need 2 duplicates in your function, it's just safer (you never know if you're going to extend your function later and have something work with that *f* variable, this is too critical to leave to chance). Even add a comment there to explain that you should never write anything to the *f* variable, just to remind yourself never to do so. You are right Irné, thank you very much for your adviseo:). Quote Link to comment Share on other sites More sharing options...
irneb Posted June 22, 2011 Share Posted June 22, 2011 Are you sure? When dwg is read only, dwl is also not eraseable:wink:.Thanks yes, I just did the check for myself. So it is possible to simply "delete" them, since they're kept open! Other than I at first thought! So perhaps that function could actually delete them in the case of EditableAfterCrash. I want it to activate upon each drawing being opened. That way it cleans all the random crap files out of the directory. We've been using this for quite some time, and we'll have everyone in the office working in drawings from the same directory and have NEVER had a problem. If a dwl or dwl2 is part of an active drawing (you or anyone else has it open), it's considered read-only and vl-file-delete just nils and moves on.Thanks Alan! That's possibly a very good piece of code I'd like to add to our library as well! Actually, running the vl-file-delete (purposefully) on a DWL of the current DWG ... I noticed it doesn't have a lag as the open function does before returning nil. So there's definitely a way of performing this much more efficiently and safely, though it's probably in C++. Quote Link to comment Share on other sites More sharing options...
Ahankhah Posted June 22, 2011 Author Share Posted June 22, 2011 Irné,, the 'ReadOnly or '(ReadOnly) flag in my code indicates that the file has been set readonly attribute:whistle:. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 22, 2011 Share Posted June 22, 2011 ; cleanup drawing directory ((lambda (path) (or (wcmatch (getvar 'dwgname) "Drawing*") (foreach file (vl-directory-files path nil 1) (if (wcmatch (strcase file) "*.LOG,*.ERR,*.DWL,*.DWL2") (vl-file-delete (strcat path file)) ) ) ) ) (getvar 'dwgprefix) ) Thank you kind sir. Much appreciated. Quote Link to comment Share on other sites More sharing options...
irneb Posted June 22, 2011 Share Posted June 22, 2011 Oh, OK, then simply change the last condition in my defun to return 'ReadOnly instead of UnknownReadonly. BTW, if you want to inspect the attributes of the file, then you can do so through the ActiveX object "Scripting.FileSystemObject": http://www.devguru.com/technologies/vbscript/quickref/file.html From that you can find the attributes bitcode: http://www.devguru.com/technologies/vbscript/quickref/file_attributes.html Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted June 22, 2011 Share Posted June 22, 2011 ; cleanup drawing directory ((lambda (path) (or (wcmatch (getvar 'dwgname) "Drawing*") (foreach file (vl-directory-files path nil 1) (if (wcmatch (strcase file) "*.LOG,*.ERR,*.DWL,*.DWL2") (vl-file-delete (strcat path file)) ) ) ) ) (getvar 'dwgprefix) ) Alan, what about hard coded directory location, how it will looks like? Quote Link to comment Share on other sites More sharing options...
alanjt Posted June 22, 2011 Share Posted June 22, 2011 Alan, what about hard coded directory location, how it will looks like? swap out the (getvar 'dwgprefix) line. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 22, 2011 Share Posted June 22, 2011 Alan, In this check: (wcmatch (getvar 'dwgname) "Drawing*") Are you checking whether the drawing has been saved as yet? If I've understood your intentions, you may be better to use: (zerop (getvar 'DWGTITLED)) Lee Quote Link to comment Share on other sites More sharing options...
irneb Posted June 22, 2011 Share Posted June 22, 2011 Another thing you could do is have a list of folders to work through. E.g. say you want to also test for such files in your temp folder and support paths: (mapcar '(lambda (path) (and (vl-file-directory-p path) (foreach file (vl-directory-files path nil 1) (if (wcmatch (strcase file) "*.LOG,*.ERR,*.DWL,*.DWL2") (vl-file-delete (strcat path file)) ) ) ) ) (append (if (wcmatch (getvar 'dwgname) "Drawing*") (list (getvar 'tempprefix)) (list (getvar 'dwgprefix) (getvar 'tempprefix)) ) (LM:str->lst (getenv "ACAD") ";") '("My other folder path 1" "My other folder path 2") ) ) I've use Lee's string to list routine to split the support paths on semi-colons. Though in such case you'd probably also need to check if that folder actually exists - else it may cause errors. Thus I've added the vl-file-directory-p check. Also moved the Drawing* check outside, since you only want this happening once. Quote Link to comment Share on other sites More sharing options...
alanjt Posted June 22, 2011 Share Posted June 22, 2011 Alan, In this check: (wcmatch (getvar 'dwgname) "Drawing*") Are you checking whether the drawing has been saved as yet? If I've understood your intentions, you may be better to use: (zerop (getvar 'DWGTITLED)) Lee You know, I always forget about that system variable. In truth, the only reason I added the check was because if a drawing isn't saved, the dwgprefix return is the documents folder and I didn't want it filtering through a mountain of files that may reside in ones documents folder. code changed... ; cleanup drawing directory ((lambda (path) (if (eq (getvar 'DWGTITLED) 1) (foreach file (vl-directory-files path nil 1) (if (wcmatch (strcase file) "*.LOG,*.ERR,*.DWL,*.DWL2") (vl-file-delete (strcat path file)) ) ) ) ) (getvar 'dwgprefix) ) Quote Link to comment Share on other sites More sharing options...
alanjt Posted June 22, 2011 Share Posted June 22, 2011 Here was one I used before we switched from XP to 7 when we were having all kinds of undo error (few threads floating around about it - one I started). (defun c:CleanTemp nil ;; delete all UND* and RED* temp files (foreach x (vl-directory-files (getvar 'tempprefix)) (if (wcmatch (strcase x) "UND*,RED*") (vl-catch-all-apply (function vl-file-delete) (list (strcat (getvar 'tempprefix) x))) ) ) (princ) ) The vl-catch-all-apply isn't required, but I wasn't thinking that day and since I don't use it anymore, I don't really care. Quote Link to comment Share on other sites More sharing options...
irneb Posted June 23, 2011 Share Posted June 23, 2011 How about doing it the other way round? (defun c:CleanJunkFiles (/ path) (if (= (getvar 'DWGTitled) 1) (progn (setq path (getvar 'DWGPrefix)) (foreach wc '("*.LOG" "*.ERR" "*.DWL" "*.DWL2") (foreach f (vl-directory-files path wc 1) (vl-file-delete (strcat path f)) ) ) ) ) (setq path (getvar 'TempPrefix)) (foreach wc '("UND*.*" "RED*.*" "*.LOG" "ACIS.*") (foreach f (vl-directory-files path wc 1) (vl-file-delete (strcat path f)) ) ) (princ) ) It should be a bit quicker if there's a huge amount of files in the folder. Quote Link to comment Share on other sites More sharing options...
