Sorry, should be...
Could it be conflicting Dimension styles with the same name overwriting?
I don't know exactly but here is what I have just worked out, I did a recover on the basefile which did turn up errors then on the sheet file which didnt, I erased the offending dimensions, purged the standard style, this appears to have fixed the issue, still wish i knew what it was though as i looked at the standard style and saw nothing out of the ordinary.
  • Replies 24
  • DANIEL
    13
  • ReMark
    5
  • SLW210
    3
  • designerstuart
    1
Posted Images
so it is still doing it but only when i snap the dimension to an entity in the view port while in paperspace, if i make a dimension with out snapping to an entity in the view port it works fine.
I can do that here, set the viewport scale to 1/16"=1', DIMASSOC = 2, use dimlinear, look in properties and it shows the -2304. (2304 / 12 = 192)
If I change the vport scale to 1/2"=1' the dim will list at -24 in properties. I don't think it is corruption just the way autodesk handles scaling the dim.
thanks rkent! I figures it would be something as simple as a setting :)
Kindly check the units your using against the items inserted by other people, it should have the same unit.
Hope it works for you.....
