Eleni19
Getting dotted lines to show up from model space into viewport
Eleni19
I am so frustrated as I cannot get my dashed lines in my model space to show up dashed in my viewport.
I already tried MSLTSCALE = 1 in model space and PSLTSCALE = 1 and LTSCALE = 1 in paperspace.
it did not work. Anyone have any ideas?
Share this post
Link to post
SLW210
Post the file.
Share this post
Link to post
CyberAngel
In this situation I will override the linetype scale for a single line. I change it from 1 to .1 to .01 etc. If necessary I then change it from 1 to 10 to 100 etc. Eventually the pattern will appear. That will tell you what linetype scale you need to use for your drawing or for certain lines.
Share this post
Link to post
Eleni19
i may be sounding like an idiot but how can i post the file?
Share this post
Link to post
Eleni19
cyberangel- so do i click on the line in model space and start trying to adjust the scale like you said until is shows up in the viewport? is that what you mean?
Share this post
Link to post
qball
Are you married to the Acadiso linetype? Because if you change a line to Dashed or Hidden or whatever it seems to work. I've never used the Acadiso stuff, so I don't know how they're different. Except apparently they don't work here.
Share this post
Link to post
Kremer
You can alter a single lines linetype scale by selecting the line and opening properties. It should be near the top of the window. This will only alter the selected objects.
Share this post
Link to post
bennyboy86
also if changing the linetype scale doesnt work, sometimes if you ahve copied work from other drawings you may have to reload the line type for that particular drawing. go to Linetype Manager and load the line type you want even if it there, it will ask you if you want to overide say YES.
Share this post
Link to post
SLW210
Good call!
You need to use DASHED for the linetype not ACAD_ISO. ISO is usually for metric drawing not Imperial. You could use a LTSCALE of 0.0394 to make up the difference.
Share this post
Link to post
