pBe Posted September 22, 2011 Share Posted September 22, 2011 Used the function that you put the two posts ago, is necessary to do something to activate this function? a modification that I also needed to do is perform this function also for the layer "Cheio" but this problem is not too serious because I can duplicate the function and changing its name from the layer it will scan:) I see. ok then. you think you can handle the "Too_large" condition? have to step out for lunch. i'll be back an hour or so.. Quote Link to comment Share on other sites More sharing options...
luiscarneirorm Posted September 22, 2011 Author Share Posted September 22, 2011 I see. ok then. you think you can handle the "Too_large" condition? have to step out for lunch. i'll be back an hour or so.. with this condition I do not know how I can get around it I was saying that he could solve the problem of performing the function for the "base" layer, and the "cheio" layer, though not the best way to do this, I just copied the whole function and replace "base" for "cheio", and use the first version and then the other, If you can modify the function to treat the two layers then better, but this is not an issue I worry too much. Enjoy your meal Quote Link to comment Share on other sites More sharing options...
pBe Posted September 22, 2011 Share Posted September 22, 2011 Okay. What constitute a "too_large" entity? are the bounding box on yur DXF sample one of them? Quote Link to comment Share on other sites More sharing options...
luiscarneirorm Posted September 22, 2011 Author Share Posted September 22, 2011 This drawing I show below, the horizontal lines of the text boxes that limit, have more than 200, so do not fit in the recording area of the lens, just have to be placed in a "special" layer, to be dealt with later. placa3.dxf Quote Link to comment Share on other sites More sharing options...
pBe Posted September 22, 2011 Share Posted September 22, 2011 The circlemark you indicated as "curios" falls on category two.these are overlapping entities which means these entities are shown on both window. so they are two different layers.I made it that way so you wont lose information on both window. If you use the updated code the higher numbered layer will take precedence. and wont be shown on the previous window it was before. whcih one do your prefer Luis? Quote Link to comment Share on other sites More sharing options...
luiscarneirorm Posted September 22, 2011 Author Share Posted September 22, 2011 The circlemark you indicated as "curios" falls on category two.these are overlapping entities which means these entities are shown on both window. so they are two different layers.I made it that way so you wont lose information on both window. If you use the updated code the higher numbered layer will take precedence. and wont be shown on the previous window it was before. whcih one do your prefer Luis? I'm so sorry but still had not tested the code in post # 8, but it seems to me that this is just what I performs better:D Quote Link to comment Share on other sites More sharing options...
pBe Posted September 22, 2011 Share Posted September 22, 2011 (edited) Okay lets cheat so you can use it for now. i'll "fissit" later during cleanup. give me a minute EDIT: Code UPDATED: * SP2B for Base * SP2C for "Cheio" * Too_large layer for entiities that are "too large" Reminder: this quick fix is tailor made for drawings similar to you DXF sample. By the time ii'm done with the cleanup it will include error trapping and a more elegant solution for "outsiders" Hope this helps Edited September 22, 2011 by pBe See previous uploaded lisp routine Quote Link to comment Share on other sites More sharing options...
luiscarneirorm Posted September 22, 2011 Author Share Posted September 22, 2011 (edited) With the design that I put here as an example the function works correctly, but with the design that I really have to deal with (can not put here for reasons of confidentiality) happens to me this error: >>>.........SplitToLayer.lsp is now loaded.......... Type SP2B to Base Layer... Type SP2C to Cheio Layer... Command: Command: sp2c Enter Distance : ; error: ActiveX Server returned the error: unknown name: Length I was now doing some more tests with the design laid out here but with some changes, and noticed that the function does exactly what I wanted, possibly my explanation was not very good what I wanted was that it is the function entities of the layer "cheio", and then the entities of the base layer or contrariwise. but the question that worried me most was that the entities "too large" seems to be ok and I think not myself clear, but the code that I liked most was the post # 8, this code can only implement the issue of "too large"? Edited September 22, 2011 by luiscarneirorm Quote Link to comment Share on other sites More sharing options...
pBe Posted September 22, 2011 Share Posted September 22, 2011 ; error: ActiveX Server returned the error: unknown name: Length i knew that's bound to happen , i'm working on it now Luis. patience Quote Link to comment Share on other sites More sharing options...
luiscarneirorm Posted September 22, 2011 Author Share Posted September 22, 2011 Ok Ok... thank you for your interest in my problem. I edited my previous post, give a look Quote Link to comment Share on other sites More sharing options...
pBe Posted September 23, 2011 Share Posted September 23, 2011 With the design that I put here as an example the function works correctly, but with the design that I really have to deal with (can not put here for reasons of confidentiality) happens to me this error:I was now doing some more tests with the design laid out here but with some changes, and noticed that the function does exactly what I wanted, possibly my explanation was not very good what I wanted was that it is the function entities of the layer "cheio", and then the entities of the base layer or contrariwise. but the question that worried me most was that the entities "too large" seems to be ok and I think not myself clear, but the code that I liked most was the post # 8, this code can only implement the issue of "too large"? Luis, here's the plan, remember what Jeff H says about bounding box? we can do that but not for every object but only those that are selected twice, or another approach is anything selected more that twice will be considered Too_Large. Since i dont have any idea how your drawing looks like. i intend to use the latter approach. the result would be: Objects selected twice-> objects will be on two different layers Objects selected more than twice.-> objects will be considered as too_large One other thing you mentioned that you modifed the selection filter to include not just polyliens/circles, can you show me what that is? Also keep in mind, that code posted at post #8 doesnt create another layer for overlapping entities. is that what you really want? Now it would be nice if you have Express Tools, we can incorporate extrim to cleanup the entities Quote Link to comment Share on other sites More sharing options...
luiscarneirorm Posted September 23, 2011 Author Share Posted September 23, 2011 Also keep in mind, that code posted at post #8 doesnt create another layer for overlapping entities. is that what you really want? I think if you could include in the code in post #8, the "too large" option, as it is in post #17 code (if possible do it) that would be interesting to me. One other thing you mentioned that you modifed the selection filter to include not just polyliens/circles, can you show me what that is? I replace it: '((0 . "LWPOLYLINE,CIRCLE")) for this: '((0 . "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE")) in the ssget function and yes, I have the express tools. Quote Link to comment Share on other sites More sharing options...
pBe Posted September 23, 2011 Share Posted September 23, 2011 I understand Luis, but do you want the option of creating anothert object on a different layer for overlapping enitities? Quote Link to comment Share on other sites More sharing options...
luiscarneirorm Posted September 23, 2011 Author Share Posted September 23, 2011 no it is not necessary. you receive my MP? Quote Link to comment Share on other sites More sharing options...
pBe Posted September 23, 2011 Share Posted September 23, 2011 no it is not necessary. you receive my MP? Got your PM. Code at Post #17 UPDATED Type STL to run...... Revision: Objects selected twice would be tested for size if not large enough it will be on the hihger numbered layer. The Box cleanup wont be necesary anymore as we're not creating a copy of the overlapping entities. Try it for now and if you find the need for option of two instances of overlapping enitities just holler. Cheers Quote Link to comment Share on other sites More sharing options...
luiscarneirorm Posted September 23, 2011 Author Share Posted September 23, 2011 Got your PM. Code at Post #17 UPDATED Type STL to run...... Revision: Objects selected twice would be tested for size if not large enough it will be on the hihger numbered layer. The Box cleanup wont be necesary anymore as we're not creating a copy of the overlapping entities. Try it for now and if you find the need for option of two instances of overlapping enitities just holler. Cheers I wanted only those entities that were in the base layer to be treated, is it possible? Take a look at these drawings, placa4 its the original, and placa5 its after apply your function, I put some notes here placa4.zip placa5.zip Quote Link to comment Share on other sites More sharing options...
pBe Posted September 23, 2011 Share Posted September 23, 2011 (edited) Change: '((0 . "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE")(8 . "~Too_large"))) To: [color=blue](list [/color]'(0 . "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE")'(8 . "~Too_large")[color=blue](cons 8 layern)[/color]) I looked at the attached file Tell you what, it will loads easier if you use a block for your "FRAME". that way the routine will search for this blocks and process everything inside the box. but i dont think thats what you want either . but i dont quite undertand the random grouping you had on your drawing, so the routine wont understand it either. The program does everything under a set of conditions, I drew a 200x200 grid starting from 0,0 and it does what its supposed to do. again under a specific set of conditions. Tell me, how did your drawing ended up like it is to start with? Edited September 23, 2011 by pBe Quote Link to comment Share on other sites More sharing options...
luiscarneirorm Posted September 23, 2011 Author Share Posted September 23, 2011 Change: '((0 . "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE")(8 . "~Too_large"))) To: [color=blue](list [/color]'(0 . "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE")'(8 . "~Too_large")[color=blue](cons 8 layern)[/color]) In the code of 17# post? I did it, but now the "too large" option, does not work Tell me, how did your drawing ended up like it is to start with? Don´t understund your question:oops: sorry:oops::oops: Quote Link to comment Share on other sites More sharing options...
pBe Posted September 23, 2011 Share Posted September 23, 2011 oops (list '(0 . "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE")'(8 . "~Too_large")(cons 8 [color=blue](strcat layern "*")[/color])) As for the question, what i'm trying to say is, Random doesnt always work with Sequential routine especially without user input. lets pause for a while and think about it. "How would set up my RAW drawing to work with sequential routine without user intervention ? " aaahhh YES! make the RAW drawing on a grid (if possible) OR create a complex routine to adapt to random mode. which one is easier.... ponder ponder..." Quote Link to comment Share on other sites More sharing options...
luiscarneirorm Posted September 23, 2011 Author Share Posted September 23, 2011 um, I know that maybe is too complicated, but what I really needed was that the scan was "smart" ... I'm not sure how to explain, perhaps seeing the next drawing (plus one:o) understand. I put some notes in the drawing to try to explain placa6.dxf Quote Link to comment Share on other sites More sharing options...
