NcD Posted December 1, 2011 Share Posted December 1, 2011 Help me. I worked in a drawing(#1) a few weeks ago and since then have copy pasted the drawings to be scaled at 1 1/2" into another drawing(#2) and have since been only working in this drawing(#2). In the original drawing(#1), I was able to scale my drawings at 1 1/2" without any problems but in my second drawing(#2), when I try to scale drawings at 1 1/2" all of my annotative bubbles get ridiculously small. Once having discovered this, I copy pasted my second drawing'(#2) components into a 'Copy' of my original drawing(#1), thinking that my second drawing(#2) file might have been contaminated, but with no luck because I could see that within the Same viewport scaled at 1 1/2" the original drawing(#1) was scaled properly but the second drawing'(#2) symbols became very small. I am stuck. thanks. Quote Link to comment Share on other sites More sharing options...
Cadologist Posted December 2, 2011 Share Posted December 2, 2011 It may be the INSUNITS system variable. Check to see if the settings are the same between drawing #1 and drawing #2. INSUNITS is a system variable that controls that automatic scaling of blocks (ie: your annotative bubbles in this example) to the units of the drawing. Also check out the -dwgunits command and in there is a 'scaling' option as well. Some things to check out anyway, hope this helps a bit. Quote Link to comment Share on other sites More sharing options...
