RobDraw Posted February 10, 2012 Posted February 10, 2012 So, given that, the OP should have everything he needs to know to get the result he is looking for. Yes? Quote
Filribeiro Posted February 10, 2012 Author Posted February 10, 2012 Here is a dynamic block that when i explode it, HE GROWS!!! DBLOCK.dwg Quote
ReMark Posted February 10, 2012 Posted February 10, 2012 Could it have anything to do with 1) the scale the block was created at or 2) the scale of the drawing it has been inserted in? Quote
Filribeiro Posted February 10, 2012 Author Posted February 10, 2012 I don't know. I just want a drawing just like the original one. Not like the exploded one. The final result should be a perfect copy of the original drawing but without the dynamic block part, i.e., a group of lines/circles/polylines Quote
nestly Posted February 10, 2012 Posted February 10, 2012 I don't believe that's a dynamic block. I have serious doubts that it's possible to crop a block to an xclip boundary automatically. Quote
Filribeiro Posted February 10, 2012 Author Posted February 10, 2012 But there is any way to reproduce the "thing" that i have sent here with simple entities? Quote
ReMark Posted February 10, 2012 Posted February 10, 2012 Why do you need to have a perfect copy of the drawing (WBlock is the best/easiest way) without the dynamic block part? What difference does it make? What are you going to do with this perfect copy after you have created it? Are you sending it to someone but you do not want to include the dynamic blocks because you don't want this person/company to have access to them? Quote
Filribeiro Posted February 10, 2012 Author Posted February 10, 2012 Because i need to clean very heavy drawings with tons of blocks and dynamic blocks and i want a final result without them. Quote
RobDraw Posted February 10, 2012 Posted February 10, 2012 I think the blocks using XCLIP are the major issue. I cannot think of a way to explode them and automatically erase/trim entities beyond the XCLIP. Quote
Filribeiro Posted February 10, 2012 Author Posted February 10, 2012 Purge and Audit doesn't solve anything. It doesn't change the blocks... Quote
nestly Posted February 10, 2012 Posted February 10, 2012 Do a large number of your blocks have XCLIPS, as the block you posted? If not, you could export the majority of your drawing and explode all the non-xclipped blocks in one operation, then manually trim all blocks that are xclipped as a separate operation. If you have a lot of blocks that have customized xclip boundaries..... I'm not sure you're going to find a solution that doesn't involve a lot of manual editing. Quote
Filribeiro Posted February 10, 2012 Author Posted February 10, 2012 There must be a solution to "paint" all the drawing (Lisp routine) and forget the original one. RESULT: a clean drawing with just 1 layer!............ahhh so gooooooood Quote
ReMark Posted February 10, 2012 Posted February 10, 2012 Your goal is a clean drawing with everything exploded and all on one layer. Sounds like you need a custom lisp routine that can be called via a script so you can batch process a folder full of drawings. Quote
nestly Posted February 10, 2012 Posted February 10, 2012 Perhaps this will do what you need? http://www.jtbworld.com/XClipClean.htm Quote
Filribeiro Posted February 10, 2012 Author Posted February 10, 2012 YES! ..... 25$ :S But seems to be the solution Quote
irneb Posted February 14, 2012 Posted February 14, 2012 Have you tried plotting to a DXB file? Then you can use DXBIN to import just lines into one single layer. You may need to setup a plotter in ACad using the DXB driver. Quote
Filribeiro Posted February 14, 2012 Author Posted February 14, 2012 Hello! Very very close to the final solution Just one detail: When i do the dxbin, the input is totally out of scale comparing with the original drawing. How can i import it with same size of the original one? Cheers and THANK YOU!!! Quote
ReMark Posted February 14, 2012 Posted February 14, 2012 Once it is in why not just rescale it? You must have already calculated the scale factor right? Quote
SLW210 Posted February 14, 2012 Posted February 14, 2012 WMFOUT and WMFIN will get rid of the XCLIP also, might still need rescaled, though. Quote
