lamensterms Posted March 26, 2012 Author Posted March 26, 2012 sure thing mate, you using ProSteel as well? http://dl.dropbox.com/u/40227213/Big%20Empty.zip Cheers. Quote
elastomero Posted March 9, 2014 Posted March 9, 2014 I had a Problem with a Blank DWG with a large file size. There were No objects in drawing but file size was 4.5 MB, purge, audit, nothing fix it. I made a block with all objects, and I insert that block in a new file with the Design Center . finally works, new file size 450 KB . Using Architecture 2014. Quote
Flo Posted March 3 Posted March 3 Look with Civil3D in Toolspace ; Settings ; Pipe Network ; Delete part lists like Full Part List if they exist. Quote
BIGAL Posted March 3 Posted March 3 Welcome aboard last post was 11 years ago. So it could be considered a closed post. Yes if using CIV3D it locks lots of stuff in a dwg wether its used or not. PURGESTYLEANDSETTINGS comes to mind. Quote
CyberAngel Posted March 4 Posted March 4 Then again, if people are still having the same problem, or proposing new solutions, is the issue really closed? There are bugs in AutoCAD still there since I started using it, and that's a long time. Quote
