AQucsaiJr Posted March 5, 2012 Share Posted March 5, 2012 I have exhausted all my resources on this subject. The company I purchased AutoCAD 2012 Electrical from had no answers and referred me to Autodesk. Autodesk has told me I have to just live with it because they have no plans to fix the problem, even though they recognize the issue. So I turn to the largest user group I currently have access to. Issue: When I print a drawing, regardless of page size, that contains and image, I have to wait upwards of 10 minutes before the printer sees the drawing and begins to print. The clients I work with use quite a few drawings that contain images and I have days where all I am doing is printing jobs because I have to wait so long. I have tried to change the print drivers. The printers I use are HP Laser M5035. I connect to them through a network however I have tried to connect to them directly with the same results. The only thing I have found to speed up the proccess, which i find to be rediculous, is to print the job to PDF and then print the PDF to the printer. This PDF method is faster but I don't think this should be the answer. I have had the AutoCAD retailer's technicians as well as the Autodesk technicians log into my computer remotely to fix this issue and both recognized the same issue but after a month of trouble shooting I am still at square one. Before I upgraded to AutoCAD 2012E I had AutoCAD 2009E and printing drawings with images was not nearly as bad. If I did not have to have AutoCAD 2012E I would revert back but this is not an option. Has anyone else had this problem or heard of this problem? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 5, 2012 Share Posted March 5, 2012 What are your computer specifications? What are your printer specifications? If AutoCAD to PDF to Printer is quicker than AutoCAD to printer, sounds like a printer (maybe printer memory) and/or driver issue. Thread moved to AutoCAD Drawing Management & Output Quote Link to comment Share on other sites More sharing options...
