DEEPAKRAJ Posted March 7, 2012 Author Share Posted March 7, 2012 Dear tharwat its some what useful. but if we want to check one by one . can you do the lisp which can cross check standard blocks and present block so nonstandard blocks could be highlighted. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 7, 2012 Share Posted March 7, 2012 Dear tharwat but if we want to check one by one . can you do the lisp which can cross check standard blocks and present block so nonstandard blocks could be highlighted. Could you tell me how can I filter the selected blocks to standard and nonstandard blocks ? Quote Link to comment Share on other sites More sharing options...
DEEPAKRAJ Posted March 7, 2012 Author Share Posted March 7, 2012 Dear tharwat, this is useful . i want a help from you can i get a lisp which can cross check the blocks from the standard file to my file and highlight the nonstandard blocks. which will be very useful Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 7, 2012 Share Posted March 7, 2012 It is not that easy to check between two files for their blocks at all and it is out of my ability . one solution . you can extract the name of all your standard blocks from the main drawing by a routine and after that you can use these names to check for current blocks in a drawing and divide them into two lists of standard and nonstandard by another routine also of course . Quote Link to comment Share on other sites More sharing options...
DEEPAKRAJ Posted March 7, 2012 Author Share Posted March 7, 2012 your solution is good . can you guide me how to do it.... Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 7, 2012 Share Posted March 7, 2012 First let us extract all names of your drawing that contains the standard blocks . (defun c:BlockList (/ ss i Block blockNames) ;;; Tharwat 07. March . 2012 ;;; (if (setq ss (ssget "_x" '((0 . "INSERT")))) (progn (repeat (setq i (sslength ss)) (if (not (member (setq Block (cdr (assoc 2 (entget (ssname ss (setq i (1- i))))) ) ) blockNames ) ) (setq blockNames (cons Block blockNames)) ) ) (print blocknames) ) (princ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
dbroada Posted March 7, 2012 Share Posted March 7, 2012 It is not that easy to check between two files for their blocks at all and it is out of my ability . one solution . you can extract the name of all your standard blocks from the main drawing by a routine and after that you can use these names to check for current blocks in a drawing and divide them into two lists of standard and nonstandard by another routine also of course . although that can only check that the names match. It is far harder (or at least outside my ability) to check that the block definitions are identical in both places which I thought was the task requested. Quote Link to comment Share on other sites More sharing options...
DEEPAKRAJ Posted March 7, 2012 Author Share Posted March 7, 2012 i did this then what should i do Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 7, 2012 Share Posted March 7, 2012 i did this then what should i do did you see all your standards block names prompted in the command line ? Try this one which is better than the above one to check all blocks definitions and not only the inserted ones . (defun c:BlockList (/ ss Block blockNames) ;;; Tharwat 07. March . 2012 ;;; (while (setq ss (tblnext "BLOCK" (null ss))) (if (not (member (setq Block (cdr (assoc 2 ss)) ) blockNames ) ) (setq blockNames (cons Block blockNames)) ) ) (if blocknames (print blocknames) ) (princ) ) And after that save the name of blocks that would be listed in the command line to include them later on in the second routine . But be patient , I have many things to do at the office and would write one for you as soon as I have time to do . Tharwat Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 7, 2012 Share Posted March 7, 2012 Consider this code as a draft at this moment (defun c:Test (/ BlockList stand non ss Blockname StandardBlockname nonstandardBlockname ) ;;; Tharwat 07. March. 2012 ;;; (setq BlockList '([color=red][b]"Block1" "Block2"[/b][/color]));;; [color=red][b]Put the block name that you got from the first routine instead of the block names[/b][/color] (if (and (setq ss (ssget "_x" '((0 . "INSERT")))) (setq stand 0) (setq non 0) ) (repeat (setq i (sslength ss)) (setq Blockname (cdr (assoc 2 (entget (ssname ss (setq i (1- i)))))) ) (cond ((member Blockname BlockList) (progn (setq stand (1+ stand)) (setq standardBlock (cons Blockname standardBlock)) ) ) (t (progn (setq non (1+ non)) (setq nonstandardBlock (cons Blockname nonstandardBlock)) ) ) ) ) (princ) ) (if Blockname (alert (progn (strcat " You have : < " (itoa stand) " > Standard Blocks inserted into this drawing " "\n" (strcat " You have : < " (itoa non) " > Nonstandard Blocks inserted into this drawing " ) ) ) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 8, 2012 Share Posted March 8, 2012 Tharwat a suggestion dump the blocks from the master dwg into a txt file name only and put somewhere safe. 2nd part run again on current drawing and compare the two lists. Display or write out some form of list found or not found. 3rd bit harder beyond me as part of step 1 write out the number of entities and name per block save as master txt do 2nd again for name and number of entities this is rough but would find a few changes. result this time is Found Found but changed Not found. Like a lot of us sounds simple but takes a lot of time to write and test. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 8, 2012 Share Posted March 8, 2012 Tharwat a suggestion dump the blocks from the master dwg into a txt file name only and put somewhere safe. 2nd part run again on current drawing and compare the two lists. Display or write out some form of list found or not found. That's true , and thanks for the extra clarifications BIGAL Quote Link to comment Share on other sites More sharing options...
DEEPAKRAJ Posted March 8, 2012 Author Share Posted March 8, 2012 Dear Tharwat, thank you very much but i need one thing added to the lisp, the non standard block could be highlighted what ??????????????????? Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 8, 2012 Share Posted March 8, 2012 Dear Tharwat, thank you very much but i need one thing added to the lisp, the non standard block could be highlighted what ??????????????????? You're welcome Check this one ... (defun c:Test (/ BlockList stand non ss Blockname StandardBlockname nonstandardBlockname ) ;;; Tharwat 08. March. 2012 ;;; (setq BlockList '("Block1" "Block2")) ;;; Put the block name that you got from the first routine instead of the block names (if (and (setq ss (ssget "_x" '((0 . "INSERT")))) (setq stand 0) (setq non 0) (setq sel (ssadd)) ) (repeat (setq i (sslength ss)) (setq Blockname (cdr (assoc 2 (entget (setq sn (ssname ss (setq i (1- i))))) ) ) ) (if (member Blockname BlockList) (progn (setq stand (1+ stand)) (setq standardBlock (cons Blockname standardBlock)) ) (progn (ssadd sn sel) (setq non (1+ non)) (setq nonstandardBlock (cons Blockname nonstandardBlock)) ) ) ) (princ) ) (if Blockname (alert (progn (strcat " You have : < " (itoa stand) " > Standard Blocks inserted into this drawing " "\n" (strcat " You have : < " (itoa non) " > Nonstandard Blocks inserted into this drawing " ) ) ) ) ) (if (>= non 1) (sssetfirst nil sel) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
Bill Tillman Posted March 9, 2012 Share Posted March 9, 2012 (edited) Tharwat, this is similar to a recent post I place looking for information on how to dump a list of all the blocks in my drawing. By all the blocks I mean all of them. Not the ones that have been inserted. I see by using this command: (tblsearch "BLOCK" "t288") this will list all the information about block t288, and it lists the long narrative description (4) which is what I need to identify the blocks I have against the blocks I still need to add. There are about 100 blocks in this drawing right now and I have to find someway to get my hands around what's in there and what's not. Can you assist me in how to get a listing of all the blocks in this file? OK, so I've tried this: (ssget "X" (list (cons 0 "INSERT"))) but all I get is . So now how do I access Selection Set: 31, to see what's in it. Edited March 9, 2012 by Bill Tillman Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 9, 2012 Share Posted March 9, 2012 Try something like this its actually a bit easier using VL if you want a global answer like all blocks all layers use ssget when you want to use filters as well. if you want to use ssget then you need ( ssname ss x) pulls entity number x from list remember starts at 0. (setq doc (vla-get-activedocument (vlax-get-acad-object))) ; open database (vlax-for block (vla-get-blocks doc) ; get all the blocks same as ssget (setq blkname (vla-get-name block)) ;get block name in for loop (if (not (wcmatch (strcase (vla-get-name block) t) "*_space*")) ; dont show model space etc (princ blkname) ; do what you want here ) ) ps starting to come to grips with VL Quote Link to comment Share on other sites More sharing options...
Bill Tillman Posted March 9, 2012 Share Posted March 9, 2012 Thanks BigAl, I found this: http://www.cadtutor.net/forum/showthread.php?57103-Arguments-ACET-TABLE-NAME-LIST and also this: (setq blist (acet-table-name-list (list "block" 1 4))) In the posting by Lee-Mac above I substituted 4 in the 70 field and it got the first block then crashed. So I substituted 4 for the 2 field and I got all those descriptions I'm after. But I need a way to put 2 and 4 together so I can have the block name and the associated description together. Will try the example above in your reply now. ps Coming to grips...well kind of...I'm gripping my hair and pulling it out. The example you gave works but it doesn't separate the block names. The acet-table command above lists all the blocks in quotes which makes parsing them easier for me. I just need a way to get the blocks and the descriptions in a listing together. Thanks again for the pointers...I'm still hacking but now it's time to put the monster away! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 10, 2012 Share Posted March 10, 2012 Maybe (nth blist x) no cad at moment Quote Link to comment Share on other sites More sharing options...
DEEPAKRAJ Posted April 15, 2012 Author Share Posted April 15, 2012 hey tharwat, how are hope so doing well. do you have lisp which can convert the layers data from excel to autocad. note :- only layer name , color and line type is given Quote Link to comment Share on other sites More sharing options...
