How to convert drawing Marwan system into WGS 84
afrazawan
please i want to convert Auto CAD dwg. Nahrwan 1967 system into WGS 84 so pls help me how
below i need this geometry Nahrwan 1967 center line into WGS 84
Edited by afrazawan
  • Replies 33
  • afrazawan
    12
  • ReMark
    6
  • SLW210
    4
  • Emigrato
    4
Posted Images
there is no any other way to convert suppose we have big layout so we can'nt get accurate is there is no other way.pls
Not in Vanilla Autocad, you can with AutoCAD Civil3d or Map3D.
dear im using Auto CAD 2012 and also Auto CAD MAP and civil 3D but how can i convert it into WGS 84 system pls
You have the centerline data in both coordinate systems right?
If you are going to be doing a lot of this type of work maybe a program like CoordTrans by Franson would be worth looking into.
http://franson.com/coordtrans/guide.asp?section=SupportedCountries&platform=winxp
Or one by GeoMatix....http://www.geomatix.net/datumpro/datums.htm
Edited by ReMark
Look in the help files/tutorials for Civl3D or Map3D. There's more to it than I can reply with here. If you still need help ask in the Civl3D forum.
You might try using the ALIGN command.
It won't work exactly, 'cause the two Coordinate Reference Systems refer to two different datums.
Here's my old-school approach, working on Map/Civil:
1] open the Nahrwan drawing
2] _ADESETCRDSYS and set the right reference system on Nahrwan datum
3] save and close
4] open a new empty drawing
5] _ADESETCRDSYS and set your favorite CRS in WGS84 datum
6] _ADEDRAWINGS and attach the Nahrwan drawing
7] _ADEQVIEWDWGS to view the transformation result
  • 1 year later...
3] save and close
i cant understand if you have video link or you can explain it by pic thanks
Those look like they might be commands found in Civil 3D.
Converting coordinate systems is never something I have had to do (we have surveyors on staff who do this) and I tried following Emigrato's instructions in Civil 3D and indeed they did work and seemed to work fine for me.
What don't you understand? The instructions seem to work okay...
  • 1 month later...
can you help me with this system if i send u one file change the system and send me please?
3] save and close
