ReMark Posted April 2, 2012 Posted April 2, 2012 I don't see how it could not be accurate unless you are talking specifically about the scale which is something that can be fixed. Quote
MSasu Posted April 3, 2012 Posted April 3, 2012 What else do you suggest if you want to import a drawing from autocad to photoshop? Did you tried to use the EPS format that I suggested to your in 2nd post? Regards, Mircea Quote
eleni07 Posted April 3, 2012 Author Posted April 3, 2012 Did you tried to use the EPS format that I suggested to your in 2nd post? Regards, Mircea I did, and it's better, though still not accurate, but for a reason when i try to export the whole drawing it won't open the eps. It works only when i export a part of the drawing. Quote
