marko_ribar Posted April 16, 2012 Author Posted April 16, 2012 Here, I've attached *.dwg where DTM.vlx breaks... Maybe it's only on my comp., but nevertheless my code worked... So, maybe my effort after all payed off... M.R. !!!!!DTM not working.dwg Quote
marko_ribar Posted April 17, 2012 Author Posted April 17, 2012 My I think final revision : 17.04.2012... Main algorithm improved to work faster and should be no mistakes - correct number of faces... Please, test my faster code, and if something is wrong (skipped face(s)) please report me... M.R. Quote
marko_ribar Posted April 19, 2012 Author Posted April 19, 2012 (edited) Since testing period of 2 days expired and no one had bad results, I've decided to post my 2 final codes so you can download them... One is for 100-200 pts small number of points and is correct solution, and the other one is for more than 40 pts and for big number of points - I called it net solution... If you can't wait to finish process and hit ESC - progress bar will be left so type : (acet-ui-progress-done) to get rid of progress bar... Sincerely, M.R. TRIANGULATE - MR.ZIP Edited April 19, 2012 by marko_ribar Quote
marko_ribar Posted June 2, 2012 Author Posted June 2, 2012 And the best I've found on www till now is Evgeniy Elpanov triangulate algorithm found on www.theswamp.org... It's the fastest and for now - where DTM brakes this code will finish - with no bugs (checked with my !!!!!DTM not working.dwg posted above)... Here is the code, all credits to Evgeniy... M.R. triangulate - ee.lsp Quote
Elpanov Evgeniy Posted December 3, 2013 Posted December 3, 2013 And the best I've found on www till now is Evgeniy Elpanov triangulate algorithm found on www.theswamp.org... It's the fastest and for now - where DTM brakes this code will finish - with no bugs (checked with my !!!!!DTM not working.dwg posted above)... Here is the code, all credits to Evgeniy... M.R. Thank you! Quote
Kowal Posted December 4, 2013 Posted December 4, 2013 Evgeniy thanks for sharing your Lisp triangulation. I always wanted to write this Lisp, but it seemed impossible. Now I have ideas for new lisp. Thank you! Quote
