austudent
drawing in viewport not visible in plot preview
austudent
I'm creating a new project drawing and have x-ref'd my base drawing onto the sheet to be plotted. I can see the base drawing thru the viewport while in layout, but once I try and preview my plot the drawing inside the viewport is not visible. that is, I can see the preview of my sheet border & title block, but nothing within the viewport shows on the preview screen. What am I doing wrong?
Share this post
Link to post
jammie
Hi @austudent,
Welcome to the forum!
It may be that some layers are set to no plot. From modelspace launch the layer manager. Under the layer properties theres a column for no plot - check that the layers aren't set to no plot. If that doesn't work change to paperspace. From paperspace double-click the viewport (press tab to cycle between vieports) and launch the layer dialog and check for the same. It may also be that the xref is on layer defpoints - this layer doesn't plot
Regards
Jammie
Share this post
Link to post
austudent
Hi Jammie,
That was exactly the problem - I didn't know the viewport layer was set not to plot. Thank you!
Austudent
Share this post
Link to post
jammie
Your welcome! Glad to help
Regards
Jammie
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
