seawind Posted June 5, 2023 Posted June 5, 2023 Sweep has strange behavior when the profile is not at the starting point of the path and the path does not have anti-clock direction. Checked it a lot of times and always had the same result. Quote
SatoshiQ Posted September 13, 2023 Posted September 13, 2023 On 4/25/2012 at 2:40 AM, SLW210 said: Select the swept surface>Properties>Geometry>Profile Rotation>Adjust value to suite. I still don't know where to open it in Autocad Quote
SatoshiQ Posted September 14, 2023 Posted September 14, 2023 15 hours ago, SLW210 said: Open what exactly? I mean where to select the "swept surface" Quote
SLW210 Posted September 14, 2023 Posted September 14, 2023 You can select it anywhere, then go to properties. What does properties show for the object? Quote
OMEGA-ThundeR Posted September 22, 2023 Posted September 22, 2023 (edited) if shit don't line up i usually use the 'reverse' command to make a line go from 'left to right' to 'right to left'. Usually fixes most of there orientantion errors. Its usually a matter of where the start and end of a line are. Haven't seen it used here besides physically changing the object. Just rotating shouldn't change anything. Using 'mirror' wil. Perhaps the testers here are willing to try my 'thesis'. Just run the 'reverse' command on the object (line of any kind) and just try the sweep again. For a visual aid, you can try to use an linetype that 'shows' in what direction a lines is drawn. But those usually don't work on 3D objects... in 2D its pretty obvious what the 'reverse' command does when such a linetype is applied. Edited September 22, 2023 by OMEGA-ThundeR Quote
