rob8
mtext plotting - text color
rob8
Hi folks, my first post here.. so please bear with me.
Firstly, I'm using ZWCAD which should be identical to AutoCAD but who knows...
One of the layers is in red, but when I plot the file, all the lines are red (which is OK) and the text is black... what am I supposed to do to keep the text in red?
The same happens when I export the CAD file to PDF
Thanks for your answers!!
Share this post
Link to post
MSasu
Since is about an AutoCAD clone, I can only go guessing.
Did you tried to change the way the color is attached to the MText entity and see if this help? I mean explicitly or by layer, direct to entity or from MText editor.
Share this post
Link to post
rob8
Yes, I did. I've tried both options, applying the color directly in the text editor ("bylayer" and "red") as well as to the entity (again "bylayer" and "red").
Share this post
Link to post
RobDraw
If plotting is similar to AutoCAD, then you need to look into plot styles. There is a lot to them so take a look and ask more questions if you need to.
Share this post
Link to post
