bachrock
Text Won't Rotate
bachrock
This mtext won't rotate. When I use the rotate command, the text moves around a point, but stays right side up the whole time. I remember this happening with xrefs as well. Anyone know what's happening here?
Share this post
Link to post
SLW210
You have selected "Match Text Orientation to Layout" in Text Style.
Share this post
Link to post
bachrock
Great, thanks!
EDIT: I had assumed that would work, but it didn't. I see some text styles have that box checked while others do not. Regardless of the text style, the text won't rotate as I want it to.
Edited by bachrock
Tip didn't end up working
Share this post
Link to post
bachrock
That didn't seem to do it. Any other ideas?
Share this post
Link to post
MSasu
May be useful to attach the drawing here for further investigation.
Share this post
Link to post
bachrock
I went to attach the drawing and got an ioError. The file is 0.98 MB so size shouldn't be the issue...
Share this post
Link to post
MSasu
Just strip out any other elements except the trouble-maker label prior to load.
Share this post
Link to post
bachrock
I understand that sentence up to "prior to load".
Share this post
Link to post
SLW210
Remove all from the drawing (a copy of the drawing would be best) to reduce size and then upload to CADTutor.
Share this post
Link to post
bachrock
Yeah, that's what I had done. Is 1 MB too large? That was my only guess as it didn't seem to describe the error.
EDIT: I had originally deleted most of the drawing and now just deleted all of the linework except the one bit of mtext. The file size is still the same 1 MB. Not sure why a bit of Mtext would generate such a large file.
Share this post
Link to post
SLW210
Did you -PURGE the file (notice the - in front)?
Share this post
Link to post
bachrock
No, is the idea that that will remove all these unused blocks and such that are making the file so large? Do you know what the file size limit is for attachments?
Share this post
Link to post
SLW210
Yes
1000kb limit for .dwg and .dxf
Share this post
Link to post
bachrock
Yes
I did some purging. The new file size is 947 kb. It still won't attach though. No idea why.
Share this post
Link to post
SLW210
Can you use dropbox?
Share this post
Link to post
bachrock
Unfortunately not. This is all for work and they have it blocked here. There's the old add an "s" to "http" trick, but that doesn't work for most sites including dropbox.
Share this post
Link to post
MSasu
Can you try please to transfer the trouble-maker text entity to a new, empty drawing? Just test if still present the said behavior and try to attach that file - it should be considerably smaller then current one.
Share this post
Link to post
rickh
Is it possible the text you are trying to rotate is a civil 3d label and not mtext?
Share this post
Link to post
bachrock
Under properties the text is listed as Mtext.
Share this post
Link to post
bachrock
I would think that file would be considerably smaller as well, but it is not. The same thing happens to the text.
Share this post
Link to post
