netman Posted August 5, 2012 Author Posted August 5, 2012 Ok. I already made the folder and COPIED the two folders into it. I will delete the Copies out of that folder.... no harm, no foul...all is good. stand by Quote
ReMark Posted August 5, 2012 Posted August 5, 2012 The only two items that should be in this new folder are copies of the custom hatch patterns. No zip files. No other PAT files from AutoCAD. And certainly no other folders which additional files in them. Quote
netman Posted August 5, 2012 Author Posted August 5, 2012 I have the entire ZIP file in its folder, inside the NEW C:\ Custom Hatches I'll do one custom hatch just to see it work tehn get the other later. This is actucally the one I need. Quote
netman Posted August 5, 2012 Author Posted August 5, 2012 I will UNZIP and place just the PATTERNS. Quote
ReMark Posted August 5, 2012 Posted August 5, 2012 Good. Start AutoCAD LT and create a new drawing. Are you working in metric or imperial units? Quote
netman Posted August 5, 2012 Author Posted August 5, 2012 I unzipped the file. I have the patterns ( codes) copied. When I go back to the C:\Custom HAtches i can not use PASTE NOTEPAD is being used to open this zipped file. Quote
ReMark Posted August 5, 2012 Posted August 5, 2012 You cannot open a zip file using Notepad. I thought you said you had already extracted the two hatch pattern files from the zip file. Now it appears you didn't. Quote
netman Posted August 5, 2012 Author Posted August 5, 2012 I simply clicked on the Zipped file and it opened. I copied the patterns. I had no trouble placing them in the PAT files inside AutoCAD, but they will not copy to this empty folder. Quote
netman Posted August 5, 2012 Author Posted August 5, 2012 *DIAPLT, CDH DIAMOND PLATE SIMPLE 45, 0,0, 1.125,1.125, 1.25,-1.00 135, .08839,.7955, 1.125,1.125, 1.25,-1.00 *EXPMTLGD, EXP MTL GUARD 1/2 #13 FLAT 14.84223, 0,0, 0,.25616 165.15777, 0,0, 0,.25616 *EXPMTLGTG4, EXP METAL GRATING 4.0# 15.16245, 0,0, 0,.91375 164.83755, 0,0, 0,.91375 *EXPMTLGTG314, EXP METAL GRATING 3.14# 18.33493, 0,0, 0,1.54547 161.66507, 0,0, 0,1.54547 *EXPMTLCOMP, EXPANDED METAL COMPLEX 26.56505118, 0,0, 2.73918327,-.39131190, 1.95655948,-9.78279740 0, 1.75,.875, 2.625,.875, .875,-4.375 153.4349488, -.875,0, 2.73918327,.39131190, 1.95655948,-9.7827974 *DIAPLTCOMP, DIAMOND PLATE COMPLEX 45, -.06629126,.06629126, 1.125,1.125, 1.25,-1.00 45, .06629126,-.06629126, 1.125,1.125, 1.25,-1.00 135, .02210709,.72920387, 1.125,1.125, 1.25,-1.00 135, .15468961,.86178639, 1.125,1.125, 1.25,-1.00 135, .06629126,-.06629126, 1.125,1.125, .1875,-2.0625 135, .95017474,.81759222, 1.125,1.125, .1875,-2.0625 45, .02209709,.72920387, 1.125,1.125, .1875,-2.0625 45, -.86178639,1.61308734, 1.125,1.125, .1875,-2.0625 *19W4GRATE, Grated area 0, 0,0, 0,1.1875 90, 0,0, 0,4.00 *19W4GRATE COMP, Grated area 0, 0,0, 0,1.1875 0, 0,.1875, 0,1.1875 90, 0,.1875, 0,4.00, 1.00,-.1875 It always opens in NOTEPAD... Quote
ReMark Posted August 5, 2012 Posted August 5, 2012 I don't see why not. I'm using Windows 7 and have done it three different times now. Open two instances of Windows Explorer. In the left one make sure you can see the two custom hatch patterns. In the right right make sure you can see into the new folder. Drag and drop the PAT files from the left window into the folder on the right. Quote
ReMark Posted August 5, 2012 Posted August 5, 2012 You cannot open a zip file with Notepad. What you posted above is the actual PAT file. There is no need to open it. Quote
netman Posted August 5, 2012 Author Posted August 5, 2012 1. when I open the ZIP file there is a PAT.Carter file ( the author) 2. when i open the PAT. Carter file I see the codes ( patterns) 3. when I get the codes ( patterns) there are spaces inbetween each code ( the coedes were all lumped together at first and now they are separated by one space... whcih if these should I place in the C:\Custom Hatches Quote
ReMark Posted August 5, 2012 Posted August 5, 2012 You have one PAT file and there are multiple hatch patterns within it? Fine. Put that ONE pattern file in the new folder. Please hurry...I think my time here on earth is about to expire. Quote
netman Posted August 5, 2012 Author Posted August 5, 2012 Nothing. I tried to drag the patterns into the second window and nothing. I wil work on this or get someone over here with experince in Windows 7. This is a brand new computer for me and a serious upgrade from what I had. I may have set something off line. IF I can get the patterns by themselves into the CUSTOM HATCH folder..... what then? Quote
ReMark Posted August 5, 2012 Posted August 5, 2012 Then you would open AutoCAD, go to Options, and add the path (C:\CustomHatch) to the Support File Search Path. Right click on the PAT file and select COPY. Then go to the CustomHatch folder open it (there should be nothing in it), right-click and select PASTE. Quote
netman Posted August 5, 2012 Author Posted August 5, 2012 OK something good happened. I went abck to the two hatches you sent me unbder ELONGATED MESH. I put them directly into the CUSTOM HATCH folder as Diamond head and Spandex Nothing opened, just like that. I went to Auto CAD and put in the same folder under ADD. I can access both of them when I put that Carter PAT it rejects it saying there is something wrong with the PAT.Carter So now, i can at least put in hatches. Quote
ReMark Posted August 5, 2012 Posted August 5, 2012 Why you elected to try and use this PAT.Carter file I don't know but after looking at the name I bet you have to rename the file and delete the portion that reads .Carter as that is probably what is throwing AutoCAD off. Quote
netman Posted August 5, 2012 Author Posted August 5, 2012 OK. I have this almost under control. I will go back in to the old download and download the exact file as it was written. I have no idea why or what I put with that Carter file.Whatever it was it was purely by error. Regardless, i now know how to add HATCH files and that is something I did not ever think would happen. To all those who have followed this thread I want to acknowldege that REMARK has taken hours of his time to educate me in this . I am not sure of anyone else who would have had the patience to guide a novice like myself through all these ins and outs. My thanks to you and if i can ever help you in anything let me. I will be back with questions i am sure, but none as difficult as this one. thank you one again. I will sort out the carter.pat thing. on my own . Reagrds.... Quote
ReMark Posted August 5, 2012 Posted August 5, 2012 You're entirely welcomed. Now I have to go and rehydrate myself. Whew! Quote
