jackiexii
Visual Studio 2013
jackiexii
Hi, I have autocad 2013 and the ultimate version of visual studio 2012 which just came out today I believe. After installing it though I could not find the autocad vb plugin when creating a new project. Is this normal because it's so new or is there something to be done to solve this? Of course I do have the latest versions of ObjectARX and Autocad .NET API as I have the plugin option on visual studio 2010 just fine.
Thanks
P.S I switched between .NET 4.5 and 4.0 but was unable to find the plugin in neither.
Share this post
Link to post
BlackBox
Welcome to CADTutor!
Visual Studio is a stand alone application, which requires an AutoCAD template either be created or installed via 'wizard'.
I am unsure if this will properly install given that you're using Visual Studio 2012, but there is an 'AutoCAD 2013 DotNET Wizard' which can be downloaded from Autodesk Developer Network.
HTH
Share this post
Link to post
