jaredmccullough Posted August 16, 2012 Author Posted August 16, 2012 Sorry for the frustration I was having issues understanding exactly how the CLIP functioned operated. I didnt understand that you first had to have the viewport selected then use the clip command then chose the new pline and I kept getting the select a point option. What were you refering to when you said "Then it was a matter of using mview, object, and pick the circle, and then went again to pick the ellipse." Were you referencing setting up the actually objects to make them viewports? If so was that not already done in the file I sent or did I screw that up? Thank you for all your help rkent Quote
rkent Posted August 16, 2012 Posted August 16, 2012 Two of them were already in the file. I was just reiterating the procedure. Quote
