maratovich Posted October 28, 2012 Author Posted October 28, 2012 Thanks for the help! This mysterious Russian soul ..... Problemma essence in the original: Есть труба. С помощью этой трубы и команды Flatshot можно получить вид сверху. На получившемся виде автоматически чертится осевая линия у всех труб. Не надо чертить вручную осевые линии. Но есть проблема - труба не вытягивается более 10000. С трубами меньшей длины всё отлично. Но иногда нужны длинные трубы, например 20000. Quote
JD Mather Posted October 28, 2012 Posted October 28, 2012 Yes, I used this method. Length is increased to 10000, and more impossible. Change your units to remove number of zeros -dwgunits. AutoCAD (and other CAD programs are limited to a specific boundary box due to floating point math calculations). Also work around the origin (0,0,0) as the centroid of your design. Quote
maratovich Posted October 28, 2012 Author Posted October 28, 2012 Change your units to remove number of zeros -dwgunits. Thank you. I will do it. Quote
JD Mather Posted October 28, 2012 Posted October 28, 2012 I see you are using 2009. I'm not sure the command -dwgunits existed back then. Let me know if it works. Quote
maratovich Posted October 28, 2012 Author Posted October 28, 2012 Yes, the command is executed. In 2009, there is a team. Quote
