sean214 Posted November 6, 2012 Author Posted November 6, 2012 Okay Got it I have to mark this off on the first test for 3 or 4 students every year. I'm not the best speller myself, but this one you need to know. Quote
Dadgad Posted November 6, 2012 Posted November 6, 2012 I have to mark this off on the first test for 3 or 4 students every year. I'm not the best speller myself, but this one you need to know. Some times when we are really under the gun, and I have been going hard from 7:00 a.m. til 4:45 a.m., a couple days in a row, my last drawing of the extended day might well have 'dementians' . Quote
ReMark Posted November 6, 2012 Posted November 6, 2012 sean: Post an image. Let's see what you have so far. Quote
SLW210 Posted November 6, 2012 Posted November 6, 2012 (edited) If you stay in this field, you might want to learn how to spell dimension (there is no "t", at least not where I live). If they stay in this field, they will be spelling it "dementia". Edited November 6, 2012 by SLW210 Quote
sean214 Posted November 6, 2012 Author Posted November 6, 2012 as long as it sounds like it... i completed the drawing Quote
JD Mather Posted November 6, 2012 Posted November 6, 2012 Diameter symbols (Ø) missing on two dimensions. %%C or Alt 0216 (using numerical keypad) or select from Symbols. Quote
sean214 Posted November 7, 2012 Author Posted November 7, 2012 You definitely have an eye for detail...thanks, will add them Diameter symbols (Ø) missing on two dimensions.%%C or Alt 0216 (using numerical keypad) or select from Symbols. Quote
ReMark Posted November 7, 2012 Posted November 7, 2012 Disable the Lineweight option when you do a screen capture it makes the image difficult to read. Not sure I agree with the way you have called out the arcs (re: R6). For future reference, dimension lines can be broken in AutoCAD 2012 using the DIMBREAK command. Quote
