cad_ede Posted February 26, 2013 Author Posted February 26, 2013 MSasu thanks for the explanation How should I search to learn more about scripting in autocad? If they can pass thank tutorials and examples. thank you Quote
BIGAL Posted February 26, 2013 Posted February 26, 2013 cad_ede Your very first post asked how to draw a rectang from co-ords that is why I used the C to close after I drew 3 lines I could also have added the first point as the last co-ord also. Some hints circle has cen pt & radius or a 2 pt circle eg CIRCLE 2p pt1x,pt1y pt2x,pt2y arcs has multiple ways to draw 3pts, start -end radius plus more options. Like Msasu write down the commands as you do them thats a script. Quote
MSasu Posted February 26, 2013 Posted February 26, 2013 How should I search to learn more about scripting in autocad?If they can pass thank tutorials and examples. First, you may investigate the dedicated tutorial available here, on CADTutor. Next, may check the links proposed by ReMark in this previous discussion. Quote
