Convert Surface To Solid in AutoCAD 2002, Is It Possible?
.... use the THICKEN command to convert a surface to a solid.
Maybe the reason why my original solution was rejected is because the OP isn't aware of the solidedit shell command?
I don't recall any problem description parameter of wall thickness by the OP.
More information is needed on the design intent.
  • Replies 22
  • ReMark
    8
  • f700es
    5
  • JD Mather
    5
  • spinecad
    2
Posted Images
Well I wouldn't suggest that anyone using this method specify a distance of a foot, meter, mile, or light year. Could use something so small (0.00001) that it would be barely noticeable.
Another method, if they are 3Dfaces:
EXTRUDE with direction (or path, I can not remember in 2002)
UNION
SLICE
Edited by GP_
