dearprudence101
Sphere won't traject down ramp
dearprudence101
Hello all,
I've created a simple room with a sphere that rolls behind an occluder on a ramp. The ramp is made from extruding a line. When I use Trajectory----"conform from" and try to select the line, it doesn't seem to recognize it. In other words, the sphere is not conforming to the extruded line.
I'm not sure what's going on, because if I create a simple line, the sphere will traject down it. If someone could take a look and figure it out, it would be a huge help.
Thanks :D
Box3.max
Share this post
Link to post
Cad64
I don't have 2013 so I can't open your file, and I'm no expert on animation, but I believe you have to use a spline as your animation path, not an extruded line.
Maybe this tutorial might help:
Share this post
Link to post
Raudel Solis
Path constraint = profit
typically you will have to reverse your initial position values
0-100
0 being the start
100 being the end point.
Share this post
Link to post
Raudel Solis
Also you might want to try telekinesis.
Share this post
Link to post
