resullins Posted April 19, 2013 Share Posted April 19, 2013 Ok... I need some help here... we have a whole batch of drawings with nothing but some Xrefs and viewports in them, and somehow they're HUGE!!!! Ok, they're not overly gigantic, but there's nothing in them. I've been systematically erasing everything in them. I started @ 2.1MB, I have erased and detached two Xref's, erased and purged a block, and nothing works. I'm now down to 1.9MB, and the file has one viewport, one small black, and 15 pieces of dtext in it. Why is it still 1.9MB?!?!? This wouldn't necessarily be a problem, but the entire series of working files for a project are like this! I can't post it here... but if there's someone that could take a look at it for me, I would be greatly appreciative! Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 19, 2013 Share Posted April 19, 2013 Have you used the commandline -purge, started by purging the regapps, and finishing by purging ALL? if you haven't already, that should help. My guess is they were created on a non autodesk package which has loaded them up with regapps. Quote Link to comment Share on other sites More sharing options...
resullins Posted April 19, 2013 Author Share Posted April 19, 2013 The only things that may have been created in a non-AutoDesk format would be the Xref's within the Xref's in that file. That file itself was created by the most incompetent Engineer in the world... but he works for my company, so I know he created it with AutoCAD. Would -purge work on embedded xref files? Quote Link to comment Share on other sites More sharing options...
resullins Posted April 19, 2013 Author Share Posted April 19, 2013 Holy ****... it just deleted 76,000 items. How have I never found this command before? It's still saving, so I'm not positive that was the problem, but I'm guessing that 76,000 regapps is not a GOOD thing. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 19, 2013 Share Posted April 19, 2013 I am not really sure if it will or not, but the commandline purge with the leading hyphen included is the most powerful tool I know of for cleaning house. Select REGAPPS first, no need to name them, just accept the wildcard search asterisk, and after running that try it again, selecting ALL, no need to name them, just accept the default. Then audit them to see if anything is out of whack. I just sent you a pm. if you want a second opinion. It won't damage them, that much I know. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 19, 2013 Share Posted April 19, 2013 After this virtual high colonic, I suspect your file will be feeling appreciably more nimble and light on the feet. Rack 'em! Quote Link to comment Share on other sites More sharing options...
resullins Posted April 19, 2013 Author Share Posted April 19, 2013 Jesus, Mary mother, and Joseph... it's 303 kb now. Thank you thank you thank you thank you! Now I just have to find someone to do that to all my files! Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 19, 2013 Share Posted April 19, 2013 While you are at it, you may as well set your ISAVEPERCENT to zero, and do a fresh save. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 19, 2013 Share Posted April 19, 2013 I have a button my desktop which runs that on every file before I save it, which also audits, and tells the audit function to fix any problems discovered. The ISAVEPERCENT won't be nearly as impressive, but it could reduce file size quite a bit too, as the default ISAVEPERCENT setting is 50, which represents 50% of file size, In those cases where there is a problem, that approach will often sort it out. Glad to help. Quote Link to comment Share on other sites More sharing options...
resullins Posted April 20, 2013 Author Share Posted April 20, 2013 K, is there ever a reason purging your regapps would make a file larger? Cause I just did that! Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 20, 2013 Share Posted April 20, 2013 I guess by definition, as it just happened, there must be, but that is a new one in my book. You should AUDIT that file and let it repair any issues found, and see if that helps. I would even run -PURGE again and see what it does. In light of this strange twist, it is probably a good idea to either create backup copies of the files which you are trying to reduce, or else work the -purge magic on copies until you are sure you have done what you hoped to do, then resave as. Quote Link to comment Share on other sites More sharing options...
eldon Posted April 20, 2013 Share Posted April 20, 2013 I find the command STATUS often gives interesting information. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 20, 2013 Share Posted April 20, 2013 I find the command STATUS often gives interesting information. I didn't know about that one Eldon, I like it, thanks! Quote Link to comment Share on other sites More sharing options...
resullins Posted April 22, 2013 Author Share Posted April 22, 2013 @Eldon: Thanks, I'll try that. I'm gonna play around now that I'm back on my own computer at home... I was on the laptop all last week. Quote Link to comment Share on other sites More sharing options...
PotGuy Posted April 23, 2013 Share Posted April 23, 2013 Holy ****... it just deleted 76,000 items. How have I never found this command before? It's still saving, so I'm not positive that was the problem, but I'm guessing that 76,000 regapps is not a GOOD thing. On the plus side, that file may well ahve just been on the world's most extreme diet. Quote Link to comment Share on other sites More sharing options...
resullins Posted April 23, 2013 Author Share Posted April 23, 2013 Ok... so now here's the question. I've got one guy in the company, who's absolutely useless anyway, and now every time HE creates a file, it puts 100,000 regapps in there. Why would only his machine being doing this? And what can we do to fix it? Reinstall? I should also mention that at some point in time he had a nasty PDF creator that he was using, and it may still be causing issues, though he's not SUPPOSED to be using that anymore. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 23, 2013 Share Posted April 23, 2013 Ok... so now here's the question. I've got one guy in the company, who's absolutely useless anyway, and now every time HE creates a file, it puts 100,000 regapps in there. Why would only his machine being doing this? Sounds like he's starting all of his drawings from a jacked up template that's full of junk. Or maybe he keeps using the same old drawing as a starting point, deleting everything in model space and then creating his drawing. Either way, that's a problem. Quote Link to comment Share on other sites More sharing options...
resullins Posted April 23, 2013 Author Share Posted April 23, 2013 I agree... he will not follow standards no matter how many times I lay them out for him. I'm tempted to tell him to take one day off, let me remote into his computer, and just fix everything for him. He drives me insane. His files also tend to have 100 or so temp plot files in them... so you're always getting errors like plot style AVDB-PhXaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa.pc3 can not be used. Quote Link to comment Share on other sites More sharing options...
resullins Posted April 23, 2013 Author Share Posted April 23, 2013 One more question in this vein for the knowledgeable masses. Is there a good lisp, macro, etc. out there for doing this to an entire folder full of files? This is a slow process! Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 24, 2013 Share Posted April 24, 2013 Here is a macro which I have put on a button on my desktop for when I am checking drawings. But this will just do the open file upon which you are working, but very quickly. If you wanted to you could incorporate this into a script too. Quote Link to comment Share on other sites More sharing options...
