Hi,
i need total count of each layer available in Drawing.
example in fitting layer i have 30 features
pipe layer i have 45 features
fitting : 30
line : 45
i need total layers like above mentioned
  • 2 weeks later...
  • Replies 21
  • crisraj99
    9
  • pBe
    5
  • ReMark
    4
  • SLW210
    3
What count? Number of Entities? What specific properties are you wanting to count?
i need in each layer how many features available
for example
DR-DRAIN-AREA DRAIN-AD-pnt-----200
DR-DRAIN-FUNNEL FLOOR DRAIN-pnt------120
DR-FITTING-CONTROL PANEL-pnt-----55
DR-FITTING-ELBOW-pnt----25
DR-FITTING-FLOOR CHANNEL-pnt---55
like that because after this i have to migrate this drawing in to PGDB and i want to match the counts.
And features are what? Any kind of Entity? Help us out here crisraj99
i need only entity count by each layer....actually now i am swith off and swith on for counting entities in each layer i need code for counting the entities by each layer.
(defun c:demo ( / objects data)
[color="blue"](vl-load-com)[/color]
(setq data
'(("DOUBT" 0)
  ("DR-CLEANOUT-FLOOR CLEAN OUT-FCO-pnt" 0) ("DR-DRAIN-AREA DRAIN-AD-pnt" 0)
  ("DR-DRAIN-FUNNEL FLOOR DRAIN-pnt" 0) ("DR-FITTING-CONTROL PANEL-pnt" 0)
  ("DR-FITTING-ELBOW-pnt" 0) ("DR-FITTING-FLOOR CHANNEL-pnt" 0)
  ("DR-FITTING-PUDDLE FLANGE-pnt" 0)  ("DR-FITTING-RISER DOWN-pnt" 0)
  ("DR-FITTING-RISER UP-pnt" 0)  ("DR-FITTING-RODDING EYE-pnt" 0)
  ("DR-FITTING-SSPFD-pnt" 0) ("DR-FITTING-TEE-pnt" 0)
  ("DR-FITTING-VENT CONNECTION-pnt" 0) ("DR-FITTING-WASTE CONNECTION-pnt" 0)
  ("DR-OIL-INETERCEPTOR-pnt" 0)  ("DR-PIPE-AC DRAIN PIPE-lin" 0)
  ("DR-PIPE-KWP-lin" 0) ("DR-PIPE-LAB DRAINAGE WASTE PIPE-lin" 0)
  ("DR-PIPE-PUMP SOIL-PSP-lin" 0)  ("DR-PIPE-PWP-lin" 0)
  ("DR-PIPE-SEWAGE PIPE-SP-lin" 0)("DR-PIPE-VENT PIPE-VP-lin" 0)
  ("DR-PIPE-WASTE  PIPE-WP-lin" 0) ("DR-PIT-NEUTRALIZATION-ply" 0)
  ("DR-PIT-SEWAGE EJECTION-ply" 0) ("DR-PUDDLE SLEEVE-lin" 0)
  ("DR-PUMP-SUBMERSIBLE PUMP-pnt" 0) ("DR-SENSOR-pnt" 0)
  ("DR-TEXT" 0) ("DR-TRENCH-Ply" 0) ("DR-VALVE-GATE VALVE-pnt" 0))
     (vlax-for layout (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object)))
   (vlax-for i (vla-get-block layout)
     (if (setq f (assoc (Vla-get-layer i) data))
         (setq data (subst (list (car f) (1+ (cadr f))) f data))
[b][color="blue"](textscr)[/color][/b]
     [color="blue"] (foreach itm data
        (if (not (zerop (Cadr itm)))
          	(princ (Strcat "\n\"" (car itm) "-----> "  (itoa (Cadr itm))))
        ))[/color]
Edited by pBe
(vl-load-com);<-----
Dont see anything wrong with it crisraj99 .. maybe you need to add (textscr) to see the result.
or if you want to it to "look" like your sample"
(foreach itm data
In case you guys are wondering why VL and not Vanilla.... ODBX at the ready]
Edited by pBe
I moved your posts to a separate thread.
Feature count? As in a count of the number of blocks per layer?
NO not only blocks what ever entities (Point line polyline text and polygon) in layers
i need layer wise count.
It's helpful to be specific.
One non-lisp option would be to use the QSELECT command. See your Help file re: Count Objects Within a Drawing. I don't know if this could be automated via a lisp routine.
for example
i switch on DR-FITTING-TEE-pnt layer and i found 13 entities.
as like i need all layer count in csv file.
not only that drawing i have so many drawings to do like that.please do the need .thanks in advance.
Count & Highlight Any AutoCAD Entity.
http://www.simplecad.com/count-highlight-any-autocad-entity.htm
ToolPac by DotSoft has the ability to count objects by layer.
Object Count by Layer: Layer Object Count breakdown by type with report or optional table. Look under the "Inquiry" section.
http://www.dotsoft.com/toolpac.htm
One last option would be to use the Data Extraction command (EATTEXT) that comes with AutoCAD. You can set this up to be as specific as you want. Output can be to a mdb, xls, csv or txt file.
  • 3 weeks later...
Finally i found the Code
I think this form will help me but no one can give me this code....
(vl-load-com)
(defun c:FCNT( / lays lay sel f tcnt )
(setq lays (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
(setq f (open "c:\\Temp\\Feacount.txt" "w"))
(write-line (strcat "LayerName" "\t\t\t\t" "Count") f)
(write-line "---------------------------------------------------" f)
(setq tcnt 0)
(vlax-for lay lays
(setq Lname (vla-get-name lay))
(setq sel (ssget "x" (list(cons 8 Lname))))
(if sel
(setq len (sslength sel))
(setq tcnt (+ len tcnt))
(write-line (strcat Lname "\t\t\t" (itoa len)) f)
(write-line (strcat "TotalCount----------" "\t\t\t" (itoa tcnt)) f)
(close f)
(command "notepad" "c://Temp/Feacount.txt")
Didn't you get a lisp routine in post #8?
Couldn't you have used the DATAEXTRACTION command?
