  • Replies 21
  • crisraj99
    9
  • pBe
    5
  • ReMark
    4
  • SLW210
    3
Didn't you get a lisp routine in post #8?
Well, i wasn't aware the OP is not targeting a specific layer from a list. hence the reply "its not working [crisraj99]" :)
FWIW
(defun c:WLTT (/ data fl opt run ef) ; write layer count  to text
(setq data nil)
(vlax-for layout (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object)))
   (vlax-for i (vla-get-block layout)
       (Setq fl (vla-get-layer i))
(setq data
                  (if (setq ex (assoc fl data))
                      (subst (list fl (1+ (cadr ex))) ex data)
                      (cons  (list fl 1) data)))))
(initget "Yes No")
(setq opt (cond ((Getkword "\nWrite to file [Yes/No]: "))("Yes")))
(setq run
(if (and (setq opt (Eq opt "Yes"))
        (setq ef (getfiled "Save data file" (getvar 'Dwgprefix) "txt" 1 ))
        (setq f (open ef "w")))
   	(lambda (o) (write-line (Strcat  (car o) "-----> "  (itoa (Cadr o))) f))
       (lambda (o) (print (Strcat  (car o) "-----> "  (itoa (Cadr o))))))
      (foreach itm data
        (if (not (zerop (Cadr itm)))
          	(run itm))
     (if opt (progn
                   (close f)
                   (startapp "notepad" ef)) (textscr))
