Interesting as a ex salesman for selling Civil solutions I have posted before a theoretical solution to string "FIELD SURVEY" points, its actually easy, it needs two things a pt number and a code.
You use the code to associate a string of points to be joined together as an example a road c/l = 01RDCL left edge = 02Redge Right edge = 03Redge.
A tree is 00tree1 the 00 implies that's its a point and a block Tree1 should be used.
Our surveys can be 10,000 pts+ etc a good day is around 3,000 pts recorded.
I have never written the code as others have done it with much more smarts.
Try 33F*04BI this is a fence with house boundary 4 00tree1*3 3m dia tree1.
So just take a csv pt list sort on code first then secondary sort on each code group
23 00tree1
24 00tree1
1 01F
2 01F
3 01F
34 02F
35 02F
I like my survey crew using line codes but have found on smaller projects (say a few blocks in town) even just having point codes placed on separate layers speeds up the drafting requirements for Centerline, EOP, BOC, ... goes quick with line command and osnap.
  • Replies 61
  • pBe
    10
  • Tharwat
    8
  • ReMark
    6
  • neophoible
    6
eea123 Our template has around 600+ layers 1 for each code tried to keep stringing solution explanation simple
