Guest Posted July 30, 2013 Share Posted July 30, 2013 I have a problem.I am writing a *.mnu file for autocad 2000. I want to make a floating toolbar but i dont know how to write it I need to write this code in the mnu file ... Here is a part of my code ID_TopoCad [_Toolbar("Toolbar 1", _Top, _Show, 1, 1, 1)] ID_GEO [_Toolbar("Georeference", _Floating, _Hide, 1, 1, 1)] [_Flyout("Insert Georeference", "Georef16.bmp", "Georef24.bmp")] [_Button("Insert Georeference (TFW, JGW, PGW, GFW, BPW, SDW, EWW, WLD...)", "Georef16.bmp", "Georef24.bmp")]^C^C_georefimg [_Button(Export Georeference (*.JGW)", "Worldout16.bmp", "Worldout24")]^c^c_worldout please help !!!!!!! Quote Link to comment Share on other sites More sharing options...
Guest Posted July 30, 2013 Share Posted July 30, 2013 i find this code TAG1 [Toolbar ("tbarname", orient, visible, xval, yval, rows)] TAG2 [button ("btnname", id_small, id_large)]macro TAG3 [Flyout ("flyname", id_small, id_large, icon, alias)]macro TAG4 [Control (element)] (not described in this document, see AutoCAD online help) but i canot understand it !!!! Quote Link to comment Share on other sites More sharing options...
Tuns Posted July 30, 2013 Share Posted July 30, 2013 I don't know if its a problem but can you name two different parts of the file the same thing? Like you have the Flyout named "Insert Georeference" and you also have a button named the same. If the toolbar just isn't showing up could it be that you told it to be hidden? [_Toolbar("Georeference", _Floating, [color="red"]_Hide[/color], 1, 1, 1)] I've never done this I'm just trying to help you trouble shoot. Quote Link to comment Share on other sites More sharing options...
Guest Posted July 30, 2013 Share Posted July 30, 2013 ID_GEO [_Toolbar("Georeference", _Floating, _Hide, 1, 1, 1)] [_Flyout("Insert Georeference (TFW, JGW, PGW, GFW, BPW, SDW, EWW, WLD...)", "Georef16.bmp", "Georef24.bmp")]^C^C_georefimg [_Button(Export Georeference (*.JGW)", "Worldout16.bmp", "Worldout24")]^c^c_worldout i try this but nothing Quote Link to comment Share on other sites More sharing options...
Guest Posted July 30, 2013 Share Posted July 30, 2013 Any other ideas !!!! Quote Link to comment Share on other sites More sharing options...
Tuns Posted August 1, 2013 Share Posted August 1, 2013 ***MENUGROUP=[color="red"](file name)[/color] ***TOOLBARS **GEOREFERENCE_TOOLBUTTONS ID_GEO [_Toolbar("Georeference", _Floating, _Show, 1, 1, 1)] ID_IGEO [_Button("Insert Georeference", "ICON_Georef16.bmp", "ICON_"Georef24.bmp")]^C^C_georefimg ID_EGEO [_Button("Export Georeference", "ICON_Worldout16.bmp", ICON_"Worldout24")]^c^c_worldout Try that. I've only read a little bit on this so I tried my best. Where it says (file name) make sure that you only have the file name there. Example: C:\Users\Prodromosm\documents\Georeference would just be ***MENUGROUP=Georeference. Also be sure that your putting your toolbar file in the support folder for AutoCAD. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 1, 2013 Share Posted August 1, 2013 Thank you Tuns but after a lot of searching from yesterday I do this and it's work just fine.... ***TOOLBARS **ΤOOLS ID_TopoCad [_Toolbar("MY TOOLS", _Top, _Show, 1, 1, 1)] [_Flyout("Georeference","Georef16", "Georef24", _OtherIcon, TOPOCAD.GEO)] **GEO [_Toolbar("Georeference", _Floating, _Hide, 1, 1, 1)] [_Button("Insert Georeference ", "Georef16.bmp", "Georef24.bmp")]^C^C_georefimg [_Button("Export Georeference", "Worldout16.bmp", "Worldout24")]^c^c_worldout Thank you for your time Quote Link to comment Share on other sites More sharing options...
Tuns Posted August 1, 2013 Share Posted August 1, 2013 May I ask why your trying to make a toolbar the hard way? You can use the CUI to make one since you have 2012 AutoCAD. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 1, 2013 Share Posted August 1, 2013 I am making an autocad menu (since 1998 - 2013) to help me in my job. I am making now some changes because my toolbars are too big. I feel more comfortable using *.mnu files because i can manage them with my notepad.The CUI file i can not read it with notepad Quote Link to comment Share on other sites More sharing options...
Guest Posted August 1, 2013 Share Posted August 1, 2013 Just for the history can i add Tool Palettes in *.mnu file ? is it possible? ? Quote Link to comment Share on other sites More sharing options...
Tuns Posted August 1, 2013 Share Posted August 1, 2013 Just for the history can i add Tool Palettes in *.mnu file ? is it possible? ? I don't see why not. Try searching for it I'm sure there's a tutorial on it somewhere. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 1, 2013 Share Posted August 1, 2013 ok thank a lot !!! Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 1, 2013 Share Posted August 1, 2013 Editing .mnu files is a tedious and often error prone way of customizing the user interface. A simple error (ex. - mismatched parentheses) could cause the menu file to bomb. Quote Link to comment Share on other sites More sharing options...
Tuns Posted August 1, 2013 Share Posted August 1, 2013 Editing .mnu files is a tedious and often error prone way of customizing the user interface. A simple error (ex. - mismatched parentheses) could cause the menu file to bomb. Shhh! Don't let him know about the ability to customize a menu with the CUI. That's classified information! Oh... Quote Link to comment Share on other sites More sharing options...
Guest Posted August 1, 2013 Share Posted August 1, 2013 Quote Originally Posted by Tuns Shhh! Don't let him know about the ability to customize a menu with the CUI. That's classified information! Oh... I know how to do it but i prefer to use (*.mnu). I know that easier to use *.cui or *.cuix files but if you do a mistake you lose everything Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 1, 2013 Share Posted August 1, 2013 When you upgrade to a new release I suspect you have to bring your .mnu files in manually right? With a customized CUIx it is automatic. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 1, 2013 Share Posted August 1, 2013 I know how to do it but i prefer to use (*.mnu). I know that easier to use *.cui or *.cuix files but if you do a mistake you lose everything Only if you are not smart enough to retain a backup copy. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 1, 2013 Share Posted August 1, 2013 I want to ask something else.Can i save my tool palets and reload them another time . is it posible ? in CUI file saved tool palets Quote Link to comment Share on other sites More sharing options...
Tuns Posted August 1, 2013 Share Posted August 1, 2013 I want to ask something else.Can i save my tool palets and reload them another time . is it posible ? in CUI file saved tool palets All changes made in the CUI are saved on the CUIx file. So you can make a hundred tool pallets that you can go to and use at any time you need them and they will not vanish from CUI unless you delete them. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 1, 2013 Share Posted August 1, 2013 Thank you my friends . It was a very useful conversation . I learned new things today .. Cheers to all ...I have to go now. See you !!!! Quote Link to comment Share on other sites More sharing options...
