Vision
script: Line w/ 'bd transparent command doesn't allow for multiple lines to be drawn
Vision
I'm trying to use a script to draw multiple lines (from one to the next) when I have the quadrants (1-4), bearings and distances in a file...but it doesn't resume the line command from the endpoint of the last drawn line--and therefore "tweeks" (at the * in the short sample script below).
line
'bd
5000,1000
3 17.5057 164.71*
2 78.072 31
3 10.111 50
3 19.2147 116
4 66.215 297
Any hints on forcing it to keep drawing, as it does when I hand enter these commands?
NOTE: The nice thing I DID learn is that you can bi-pass the [.P .N .G] choices by just putting in the x,y coordinates to start, "tricking" it to thinking you used your mouse.
However, the script works for the beginning, but doesn't behave the same as my hand entered commands, but shows the following:
Specify first point: 'bd
>>Select starting point or [.P/.N/.G]: 5000,1000
Quadrants - NE = 1, SE = 2, SW = 3, NW = 4
>>Specify quadrant (1-4): 3
Current direction unit: degree, Input: DD° MM' SS.SS" (spaced)
>>Specify bearing: 17.5057 >>
>>Specify distance: 164.71
Resuming LINE command.
Specify next point or [undo]: 2
Specify next point or [undo]: 78.072 Zero length line created at (5224.647, 81.665, 0.000)
Specify next point or [Close/Undo]: 31
Enter BACKSPACE to interrupt script.
Command: 3 Unknown command "3". Press F1 for help.
Share this post
Link to post
Tuns
Can you post the code? It would be helpful.
Share this post
Link to post
steven-g
It could be that you need to enter 'bd before each point, I can't test it (LT), but some command modifiers only last for the following point and then the command reverts to it's original state.
Share this post
Link to post
Vision
Thanks for responding, Tuns. Here's the code I used (it was simple to test):
line
'bd
5000,1000
3 17.5057 164.71
2 78.072 31
3 10.111 50
3 19.2147 116
4 66.215 297
I also tried:
line
'bd
5000,1000
3
17.5057
164.71
2
78.072
31
3
10.111
50
3
19.2147
116
4
66.215
297
command
Share this post
Link to post
Tuns
So it draws the first line then messes up on the second, correct?
Share this post
Link to post
Vision
Good thought. That didn't work either, though. Thanks.
Share this post
Link to post
Vision
If anyone has other ideas, I'd be glad to hear (as 3 days ago was my first experimentation with scripts)--but I had much less issues with plain coordinates.
It took some work, but I used excel to convert the bearings and distances to x,y coords, and I got them to draw the lines nicely.
Share this post
Link to post
Tuns
Well that's good to hear (or read). :) I've never seen a script like that before. What is it called? The scripting language that is.
Share this post
Link to post
Vision
No. (I read that a script file could just contain the commands that you type in, but they're in a .scr file.) Am I missing something?
Share this post
Link to post
Tuns
I don't think your missing anything if it works. :lol: I was just asking because it didn't look like anything I've seen before.
Share this post
Link to post
steven-g
What is the sequence you use if you just type the commands and enter the bearings at the command line, could you do that and copy the command history, and post that here.
Share this post
Link to post
Vision
I couldn't agree more. Enjoy the weekend! 8)
Share this post
Link to post
r4n
LISP:
(defun c:lbd ()
(setq pt (getpoint "\n Start point: "))
(command "script" "u:\\scripts\\line-bd.scr")
My Line-bd Script:
line
!pt
'BD
I am putting all of my functions in one file and the scripts in on folder.
Easier to track.....ENJOY!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
