subodh_gis
Insert Block in-between two Points using Autolisp
subodh_gis
Many a times it requires to show the same block with different angle and scale. Rotating each block to a required angle, and scaling it as required will take a lot of time so can we Insert Block in-between two Points in the angle and scale of points selection using Autolisp . I am using AutoCAD 2004.
Thank You !
Share this post
Link to post
satishrajdev
Can you a show any example for this
Share this post
Link to post
gS7
Try This . I Hope Its Help You ...
Tested in 2004 version
(defun c:Test(/ b ss e en xe ye ze r)
  ;Ganesh Shetty
  ;Match Block Rotation angle & Scale
  ;2013
  (vl-load-com)
  (if
    (and
        (setq B (car (entsel"\nSelect Block:")))
 (setq ss (ssget '((0 . "INSERT"))))
          (setq e (vlax-ename->vla-object b))
     (setq en (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
     (setq XE (vla-get-XScaleFactor e)
	   YE (vla-get-YScaleFactor e)
	   ZE (vla-get-ZScaleFactor e)
	   r  (vla-get-Rotation e)
     (if (vlax-method-applicable-p en 'Rotate)
       (vla-put-rotation en r)
     (vla-put-XScaleFactor en XE)
     (vla-put-YScaleFactor en YE)
     (vla-put-ZScaleFactor en ZE)
 (princ))
Share this post
Link to post
subodh_gis
@ Ganesh Shetty
Thanks for quick reply sir
What it will do sir? Its asking to select the block and object.
Please explain how it will help me.
Share this post
Link to post
satishrajdev
Dear Subodh,
R u want a lisp, that can insert block with specific rotation and scale???
or
You want to change rotation and scale of existing block???
Share this post
Link to post
subodh_gis
I want a lisp that can insert a perticular block with rotation and scale using two clicks only BLOCK.JPG
Share this post
Link to post
satishrajdev
Here is a example for this, I hope this would help you :-
(Defun c:test ()
 (setq	ent    (car (entsel "\n Select Block :"))
bkname (cdr (assoc 2 (entget ent)))
rotp1  (getpoint "\n Specify 1st Rotation point :")
rotp2  (getpoint "\n Specify 2nd Rotation point :")
rot    (angle rotp1 rotp2)
scl    (distance rotp1 rotp2)
pnt    (getpoint "\n Specify Point to Insert Block :")
 (command "insert" bkname "_scale" scl "_non" pnt rot)
Share this post
Link to post
gS7
@ Ganesh Shetty
Kindly find the attached Drawing file for Program Guide
match block.dwg
Share this post
Link to post
neophoible
Are you saying that the insertion point of your BLOCK will match the midpoint of your two picked points? If so, then that will be an easy fix for the routine already offered. If the scale is simply the distance from one of the pick points to the calculated insertion point, then that should not be too difficult to add as well. Is that the scale factor you need?
Share this post
Link to post
gS7
@subodh,
Are You Going to Insert Different Types of Blocks ?
Kindly attach Your Block Drawing..
We are Trying to Help You ,Don't be sad
Share this post
Link to post
gS7
I found a Solution ,
1.Make Sure Your Block Dimensions is 1mm x 1mm Size
2.Make Center Point is Your Block Insertion Point
Codes.
(defun c:Test(/ bname pt1 pt2 d ang mp)
 (if
   (and
      (setq bname(getstring "\nEnter Block Name To Insert:"))
      (setq pt1 (getpoint "\nPick First Rotation Point:"))
      (setq pt2  (getpoint "\nPick 2nd Rotation Point:"))
  (if (not (Tblsearch "BLOCK" bname))
    (princ "\nBlock Not found in Drawing!")
      (setq d (/ (distance pt1 pt2) 2.0))
             (setq ang (angle pt1 pt2))
      (setq mp (polar pt1 ang d))
      (command "_INSERT" bname "_SCALE" (distance pt1 pt2) "_non" mp (angtos ang))
 (princ))
Here , Find the attachment Drawing .. your Block Should Be Like This
Myblock.dwg
Share this post
Link to post
javid
Hello dear friends:)
I read this useful post but I have a problem with this lisp...
As I tried to changing this routine for myself and i didn't succeed! :(
I need your help to have another lisp withoput changing my block scale and also without asking my block name each times i want to use this lisp (I want to write my blockname directly into that lisp).
So, I need to use just one block in to my drawing only with changing it's rotation.
I will be thankful if anybody help me to solve my problem.
Share this post
Link to post
JamCAD
javid, here is a very basic version for you to try. It will only insert the block if it already exists in the drawing
(defun c:blockmp (/ blknme p1 p2 ang)
 (setq blknme "Name of block")            ;Name of the block
 (setq p1 (getpoint "\nPick first point: "))
 (setq p2 (getpoint p1 "\nPick second point: "))
 (setq ang (angtos (angle p1 p2)))    ;Calculates the angle between points one and two
 (command "_Insert" blknme "_mtp" p1 p2 1 "" ang)
Share this post
Link to post
javid
Hi dear j0nat :)
Thank you so much for your useful help
It's working for me anf was so helpful
Thanks alot:)
Share this post
Link to post
svippala
@JamCAD
Thanks for coding
in the same code we adding scale(up/down) option is its possible
Share this post
Link to post
