Cad2762
Help needed with a Macro please
Cad2762
Hi All
I cave created a new drop down menu using the Customize User Interface in AutoCad 2011 called Load Aerial Photography with a sub menu called Insert Tiles.
When selecting my new menu I would like to have a macro that browses to where our JPEG Aerial Photos are kept on our network.
At the moment I have to select the AutoCad pull down:-
Insert, Raster Image Referance then browse to M:\DATA\AERIAL_PHOTOS\2012\84235\RGB_10cm_1km_Jpeg_Tiles
If there is a user on this Forum who can put together a Macro that will browse to the above filepath I would be very grateful as I'm really getting nowhere with this.
Thanks
Paul
Share this post
Link to post
ReMark
Is it possible that the slashes have to go the other way? Like this: / instead of like this \.
According to a reference book I have the "/" character is used to define directories. Ex. - C:/0000/bolt.dwg
Share this post
Link to post
Cad2762
The example I have given Isnt my attempt at writing the Macro its the long handed way of inserting a raster image into a drawing, what I need is someone with Macro experiance to put together a piece of Macro code that will look to the file path I have provided, hope that makes sense.
Share this post
Link to post
ReMark
You are writing a path to a directory. Reverse the slash.
Share this post
Link to post
Cad2762
Thats the point i'm not writing anything as I don't have the experiance to write Macros, if you look at a macro it has instructins like (defun c:/ (((****)) etc
Share this post
Link to post
ReMark
If you are looking at something like this...
(defun c:addtxt ( / i n r s )
...then aren't you using a lisp routine not a macro?
Share this post
Link to post
ReMark
Here is an example of a complex macro (courtesy of CADTech Seminars).
^C^C_-layer;make;TAGS;color;red;;;_-insert;c:/blocks/tag.dwg;\96;96;;\_insert;c:/blocks/scale96.dwg;$m=$(getvar,lastpoint);96;96;;_pline;$m=$(getvar,lastpoint);w;1;;\;_insert;c:/block/tag2.dwg;end;\96;96;;\\plinewid;0;
Share this post
Link to post
Cad2762
This is c copy from my CUI where it says Macro in the properties box (if c:a4comm nil (load "c:/data/lisp/a4comm"));a4comm;
Share this post
Link to post
ReMark
That macro is calling a lisp routine. Do you know what a lisp routine is?
Share this post
Link to post
Cad2762
Would you know how to put a Macro together that allow my to insert my JPEG using Insert, Raster Image Referance M:\DATA\AERIAL_PHOTOS\2012\84235\RGB_10cm_1km_Jpeg _Tiles?
Share this post
Link to post
ReMark
How's this?
^C^C-insert;M:/DATA/AERIAL_PHOTOS/2012/84235/RGB_10cm_1km_Jpeg_Tiles/insert tile name with file type here;
Share this post
Link to post
ReMark
An example of a short lisp routine as created by forum member Lee Mac.
See the difference between a macro and a lisp routine?
Share this post
Link to post
Cad2762
Yes, It's because if you loog at the image you will see in the properties box the lisp routing is title Macro.CUI.JPG
Share this post
Link to post
ReMark
That's your comeback? We're beyond that now. I wrote what I considered to be a macro that will insert a jpeg located according to the path you provided. All you have to do is add the complete file name, add the macro to your CUI and test.
Share this post
Link to post
Cad2762
How's this?
Thanks but I had tried this already, I think the problem is -insert only allows .dwg and .dxf and not jpeg files, to get a raster image in you have to use insert, Raster Image Referance or imageattach
Share this post
Link to post
ReMark
Now I'm not so sure. Is there any way to invoke IMAGEATTACH without opening a dialog box?
Share this post
Link to post
Cad2762
I have already tried this and it does not work, thanks for your imput though
Share this post
Link to post
Tuns
^C^C-insert;M:/DATA/AERIAL_PHOTOS/2012/84235/RGB_10cm_1km_Jpeg _Tiles;\1;0;
Does this work?
Share this post
Link to post
Cad2762
Does this work?
Thanks but got the message in the picture
Share this post
Link to post
Tuns
-image;attach;M:/DATA/AERIAL_PHOTOS/2012/84235/RGB_10cm_1km_Jpeg _Tiles;\1;0;
How about this? Make sure the file path and image name is correct.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
