Displaying variables and characters in an entmake dimension
plackowski
Hello! I just stared working in AutoLISP a few days ago, and I've come across a problem. I need to create a dimension line where the dimension value is dependent on an input value. So if the input is y, then the text on the dimension line should equal 4.5*(y+1) inches, and it also needs to have a character width of 0.75. Currently, it just displays 4 1/2". As I understand it, this would be a real number, meaning I can't concatenate it with the inches symbol. Any help would be greatly appreciated! :)
(defun c:retan (/ p1 p2 p3 p4 x y i j)(setvar "osmode" 0)
(setq p1 (getpoint "\nfirst corner of rectangle: "))
(setq x (getint "\nEnter Horizontal Count: "))
(setq y (getint "\nEnter Vertical Count: "))
(setq p3 (list (+ (+ 1.625 (* 0.8125 (- x 1))) (car p1))(+ (+ 1.625 (* 0.8125 (- y 1))) (cadr p1))))
(setq p2 (list (car p1)(cadr p3)))
(setq p4 (list (car p3)(cadr p1)))
(command "pline" p1 p2 p3 p4 "c") ;c closes the rectangle's fourth side
(entmakex (list
 (cons 0 "DIMENSION")
 (cons 100 "AcDbEntity")
 (cons 8 "E-DIMS")                                                       ;; 8 Layer
 (cons 100 "AcDbDimension")
 (cons 10 (list (- (car P1) 0.7) (cadr P2) 0))   ;; 10 Arrow Node
 (cons 11 (list (- (car P1) 0.9) (/ (+ (cadr P2)(cadr P1)) 2) 0))        ;; 11 Text Position
 (cons 70 160)
 (cons 1 "{\\W0.75;4 1/2\"}")                                            ;; 1  Contents of Dimension Textbox
 (cons 71 5)                                                             ;; 71 Text Alignment (5=centered)
 (cons 42 0.8125)
 (cons 53 1.5708)                                                        ;; 53 Text Rotation
 (cons 3 "REW-1_.125txt")
 (cons 100 "AcDbAlignedDimension")
 (cons 13 P1)                                                            ;; 13 point on line
 (cons 14 P2)                                                            ;; 14 point on line
 (cons 50 1.5708)                                                        ;; 50 Angle (radians) 1.5708
 (cons 100 "AcDbRotatedDimension")))
(setvar "osmode" 16383)(princ)
