surajshenoy91 Posted March 6, 2014 Share Posted March 6, 2014 I have a AutoCAD plan with roughly 1000 points . I want to display a sl. number along side the respective points and then generate A excel file with point number and their co ordinates. I am very new to AutoCAD. Can anyone give me detailed procedure how to do this?? Thanks in advance Quote Link to comment Share on other sites More sharing options...
MSasu Posted March 6, 2014 Share Posted March 6, 2014 I noticed many times discussions on this matter, so a search on the Forum for "points numbering" should give you plenty of options; an AutoLISP routine that will give you the expecting result may be later easily adapted to export in CSV (for Excel) format. May want also to take a look to the tools Lee Mac is kindly offering. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 6, 2014 Share Posted March 6, 2014 Give this a go expects a text style of pick pt, default ht =0 not preset (defun pt2txt ( / ss x y z lineans) (setq ss (ssget "x" (list (cons 0 "Point")))) (setq fout (open "C:/temp/pt2txt.csv" "w")) (setq I 0) (repeat (sslength ss) (setq pt (assoc 10 (entget (ssname ss I)))) (setq x (nth 1 pt)) (setq y (nth 2 pt)) (setq z (nth 3 pt)) (setq lineans (strcat (rtos (+ I 1) 2 0) "," (rtos x 2 3) "," (rtos y 2 3) "," (rtos z 2 3))) (princ lineans) (command "text" (list x y z ) 2.5 0 lineans ) ;pt x y z ;(command "text" (list x y z ) 2.5 0 (rtos I 2 0) ) ; pt numb only (write-line lineans fout) (setq I (+ I 1)) ) ; repeat (close fout) (princ) ) (pt2txt) Quote Link to comment Share on other sites More sharing options...
