macro mid to point doesn't work on Autoca 2014. Whi?
Ok, but I think first I'll have to test the option of Guran, before risking to destroy the keyboard.
I have to add a simple apostrophe to the macro. So quick and easy ...
I have some doubts because in Autocad 2010 tells me "error".
Anyway tomorrow I will have to test on 2014, and you'll know the response.
However, if I press F1 so quick to arrive today until tomorrow, I might even give you the confirmation within 5 minutes.
Let's try ...
  • Replies 24
  • marmo
    12
  • ReMark
    6
  • guran
    4
  • BIGAL
    2
Posted Images
Ooops,
I think I overdid it.
These do not appear to my colleagues ...
Dont understand I use m2p all the time 2013, I have a sq so line m2p pick two corners m2p pick 2 coners line is drawn centred on two squares. m2p is a like acceptable option for a lot of commands wthout the need for a ' eg 'CAL
Ok,
it seems that the focus of the problem in 2014 atocad is not possible to have a macro with no name.
The commands such as snap "end", "mid", "m2p", etc., need no apostrophe to be used in a transparent manner.
Instead, if you wanted to use a lisp in a transparent way you would type apostrophe followed by the name of the lisp.
I think the problem is that 2014 will not accept autocad lisp without a name, then the sequence apostrophe + apostrophe + enter is no accepted.
For a practical point of view the problem is easily solved using other options, instead as regards the syntax of the commands remains unsolved.
Would this actually be the name of the C:defun not the name of the loaded lisp.
