How to find * and replace with X
shailujp
I have a drawing that has texts as * and would like to replace with X using find/replace command. The AutoCAD understand or gets confused with * as wildcard and replaces all entities with X. Any ideas?
Using AutoCAD 2008.
Thanks
Please expand FIND's dialog box (there should be a button with an arrow pointing down in its left-bottom corner) and un-check the Use Wildcards option.
Ooops, seems that the dialog was changed in new versions.
Please try to precede the wildcard with an apostrophe reverse-quote or a backslash and check if this aproach helps.
or
Edited by MSasu
Fixed the name of character
Ahh..something worked. I dont know the character ` name but its above the Tab key (on the left of the 1 number). Thanks
