ILoveMadoka
Lisp to reorder a column of text?
ILoveMadoka
Does someone have a routine (or know of a way) to reorder a column of text items?
ie:
Line 1
Line 2
Line 3
Line 4
to
Line 4
Line 3
Line 2
Line 1
I have a large table of text that I need to flip the column order.
Has someone posted something along these lines?
Is there an Autocad command I don't know about?
I have had no luck in any of the search terms I have used..
Thanks for all the help you guys provide... :)
Share this post
Link to post
ymg3
Is it a true autocad table or simply line of text ?
Post a drawing
Share this post
Link to post
ILoveMadoka
Lee Mac to the rescue once again!!!
Dynamic Text Alignment v1.6
http://www.lee-mac.com/dynamictextalignment.html
I had to jump through some hoops but Lee's program made it all possible.
Could your next update allow a text column to be rotated 360 degrees instead of limiting it 180?
(seems that is how it worked)
I had to rotate the text in place 180 degrees then use Autocad to rotate the entire column 180.
Awesome! Still quite a time saver!
Thanks Lee!
ps: It was all regular text entities
Share this post
Link to post
Lee Mac
I'm glad my Dynamic Text Alignment program came in handy!
Here is another way to achieve the same result:
([color=BLUE]defun[/color] c:revtxt ( [color=BLUE]/[/color] e i l s )
   ([color=BLUE]if[/color] ([color=BLUE]setq[/color] s ([color=BLUE]ssget[/color] [color=MAROON]"_:L"[/color] '((0 . [color=MAROON]"TEXT"[/color]))))
       ([color=BLUE]progn[/color]
           ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] i ([color=BLUE]sslength[/color] s))
               ([color=BLUE]setq[/color] e ([color=BLUE]entget[/color] ([color=BLUE]ssname[/color] s ([color=BLUE]setq[/color] i ([color=BLUE]1-[/color] i))))
                     l ([color=BLUE]cons[/color] ([color=BLUE]list[/color] ([color=BLUE]assoc[/color] ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]=[/color] 0 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 71 e))) ([color=BLUE]=[/color] 0 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 72 e)))) 10 11) e) ([color=BLUE]assoc[/color] -1 e)) l)
           ([color=BLUE]mapcar[/color]
              '([color=BLUE]lambda[/color] ( a b ) ([color=BLUE]entmod[/color] ([color=BLUE]list[/color] ([color=BLUE]cadr[/color] a) ([color=BLUE]car[/color] b))))
               ([color=BLUE]setq[/color] l ([color=BLUE]vl-sort[/color] l '([color=BLUE]lambda[/color] ( a b ) ([color=BLUE]<[/color] ([color=BLUE]caddar[/color] a) ([color=BLUE]caddar[/color] b)))))
               ([color=BLUE]reverse[/color] l)
   ([color=BLUE]princ[/color])
Share this post
Link to post
BIGAL
This prompted me to a slightly different question you have 3 individual columns of text but only want to sort on 1st column wrote a export columns that joins the text into single row then using Lee-Mac's would allow sort. Any one wants it post request here. It was done to export to excel to sort.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
