Drawing 'lags' after using block editor
SAFeSTeR
Had this problem for a while now, however, I have managed to solve it so thought I would share it. Not sure if it is a common issue and I currently use AutoCAD 2012.
As the thread title suggests, sometimes after exiting the block editor, my drawing begins to 'lag'. It becomes very choppy when panning or using the mousewheel zoom and commands take a little longer than usual to respond. For me, all I have to do is a zoom extents and it's fixed, no idea how or why.
Hope this may help others in the future 8)
I as well have this issue and the only solution I have found is the one you mentioned above. It might be useful to also set up a macro/lisp to zoom extents and then zoom previous so you are right back to where you are working.
I've not seen in any of the other posts but holding down the CTRL key, after exiting the block editor, will lock the mouse cursor position until the button is released. Same solution will fix this problem.
