pramodmaharana
lisp to generate contour from xyz
pramodmaharana
Hi
Anybody have this lisp to generate contour from XYZ in xls file.
pramod
Share this post
Link to post
Snownut
Also search for triangulation, ymg has been working on the subject for sometime now, he has a very nice lisp function posted here. PLEASE before posting a request at least do a basic search on your own.
Share this post
Link to post
aloy
ymg3,
The discussions given in the link are interesting. I too tried to use two of the solutions given for the Delaunay triangulation but saw they give error messages after processing 99% of the points. They did not draw anything. I attach here the list used (about 750 points) and a snipped section of the points drawn separately.
What can be the problem?.
pointlist.lsp
Share this post
Link to post
marko_ribar
This is what I get after supplying ymg's tin command...
See attachment...
M.R.
POINTS - Delunay.dwg
Share this post
Link to post
aloy
Marko, Could you give a link to the version you used or better still if you can attach the file in a reply. I want to try it in my AutoCAD 2013.
Regards,
Aloy
Share this post
Link to post
BIGAL
I really compliment people to producing solutions available for free or nearly free but the free programs to do triangulation, contours, long sections and cross sections has been around for a long time, the free verison limited number of points, shareware unlimited, I know I downloaded well in excess of ten years ago. I believe what is missing is spageti the ability to take field code data not only create a dtm but also create create a string plan view, including breaklines, then produce long and cross sections. Take a csv level book produce a plan view did that 20+ years ago including strings yeah it had a cost. Ok go and get today a commercial product around $2,500.
Some may say I am criticizing but I am supporting I spent a significant time of my life as a Civil Software dealer so don't reinvent the wheel make it better spokes and 21"
I remember talking to software owner and discussing how many triangles per second could be produced. It was thousands remember 486.
Share this post
Link to post
ymg3
aloy,
I did run your point list and I obtain same result as Marko on first run.
Find attached the latest version. Do bear in mind that it is still a work
in progress.
ymg
TriangV0.5.5.LSP
Share this post
Link to post
marko_ribar
ymg3, yes, I used your version... Thanks a lot for your hard work... M.R.
Share this post
Link to post
ymg3
Marko,
Thanks for the kind words.
ymg
Share this post
Link to post
aloy
" I believe what is missing is spageti the ability to take field code data not only create a dtm but also create create a string plan view, including breaklines, then produce long and cross sections."
This is the most important thing. I am a C&S engineer. People do not construct road like what they do in factories. The most a developing or any other country will construct is one expressway or a highway per year. So the speed in the process of triangulation does not have much relevance. The software the designers use should be flexible to build the safest roads and allow the user to manipulate the cross section freely (fully string based) without limiting it to templates.
Share this post
Link to post
ymg3
aloy,
Here is your drawing with some triangle edited out
and contour interval at 0.1m
ymg
Aloy.dwg
Share this post
Link to post
aloy
Thanks ymg,
I too have been trying to adopt a programme originally from Burke. It was for a dynamic Delaunay triangulation which I modified for static. I found that the supertriangle did not work correctly halfway. I was however able to prevent those long line being drawn without having to erase them manually.
Thanks for you effort in this endevour.
I will try out your code later.
Aloy
Share this post
Link to post
aloy
ymg,
I only tried to get the tin and it worked as it should and will be useful for me to get the long and cross sections of road. I was also trying on a different concept without the use of supertriangle. Thanks very much.
With Best Regards to the team.
Edited by aloy
Share this post
Link to post
BIGAL
Re long sections & cross as your creating 3dfaces I am sure there is a intersect with example out there, I did a multiple line one, a long time ago, using VL-intersectwith should make this easier, only problem I see is that a pline will cross a 3d face twice, not sure how to get both sides, bit like circle answers. Will have a play. Use pline then this becomes "fence" option for selecting objects.
Share this post
Link to post
ymg3
BIGAL,
Command "c:prof" does extract the profile from 3dface.
However I am not satisfied with the interface as it is.
The getneighbour routine is too slow in the published version.
I have accelerated it by a factor of 3 (to be published).
Also as the dialog box open, I want the elevation range
to be displayed. Also want to add option for displaying
grid etc.
Badly need a good way to represent alignment including
Spirals, Circular curve and Vertical curve.
ymg
Edited by ymg3
Share this post
Link to post
ymg3
BIGAL,
Here's an alternate way to get the set of 3dfaces under a polyline.
  ;; getfencesel        by ymg                                               ;
  ;; Arguments:  en,  Linear Entity Name (Polylines, Arc, Ellipse etc.)      ;
  ;;            flt,  A valid Entity filter Ex: '((0 . "3DFACE"))  or nil    ;
  ;;   Returns: A Selection Set of Entities touching the selecting entity.   ;
  ;;  Requires: Express Tools                                                ;
  (defun getfencesel (en flt / fe px ss)
     (acet-ss-zoom-extents (setq ss (ssadd en)))
     (setq px (* 0.75 (acet-geom-pixel-unit))
           fe (acet-list-remove-adjacent-dups (acet-geom-object-point-list en (/ px 2.0)))
           ss (if flt (ssget "_F" fe flt) (ssget "_F" fe))
Once you have the selection set, there is basically two ways.
You can exploit information in ssnamex or go with the intersectwith method.
Right now the version you have makes use of a third method which utilize the
Lawson's walk to locate which 3dface is under a given point on your selecting poly.
ymg
Share this post
Link to post
aloy
ymg3,
To my mind what is needed is to follow civil3D closely and do what ever enhancements later. That is also a way of not re-inventing the wheel. As for the centerlines (with or without spirals) were done way back in early 90s. Even the flexible cross section were also done at that time and roads/highways were constructed. At that time the survey was always done on a defined centerline. Now I have to find a way to fix two IPs and move the other with the mouse( perhaps with the help of LeeMac), while my horizontal alignment program runs and give the points at regular intervals. ymg3's Lawson walk can locate the triangle and get z (with vector dot and cross products). Another snippet can produce the long section base on which the cross sections can be produced. It appears to me the process is 90% complete (except for the quantities) and summit of MT. Everest is in sight.
Regards,
Aloy
Share this post
Link to post
ymg3
Normally for Cross Section, what I plan to implement
is yet another dialog where you would choose an alignment
and then extract section of a given width at a given interval
including the significant points of the alignment. (tc ct etc.)
ymg
Edited by ymg3
Share this post
Link to post
