lisp to generate contour from xyz
The theory for a point on a 3 point surface is easy to find, in this case it would use a 3dface.
You should ask ymg3 if he has added this option.
  • 2 years later...
  • Replies 41
  • ymg3
    14
  • aloy
    12
  • BIGAL
    6
  • manohar
    3
Posted Images
On 4/29/2014 at 2:28 PM, ymg3 said:
aloy,
I did run your point list and I obtain same result as Marko on first run.
Find attached the latest version. Do bear in mind that it is still a work
in progress.
ymg
I appreciate this Lisp wonderful.
Put I wonder why is not work for this point.
Please help.
Warning: this topic has not been posted in for at least 120 days.
Unless you're sure you want to reply, please consider starting a new topic.
OGL_a.dwg
Edited by moha_aga
