blowther
Determine what a viewport's custom scale is
blowther
Hi all,
Does anyone know of a way to determine what the custom scale of a viewport is?
I have some existing drawings that are using non-standard scales and simply state 'Custom' in their properties window.
Share this post
Link to post
designerstuart
i know a workaround.....
make a line in paperspace over your viewport. make it say 100mm long. copy it so you have 2.
use CHSPACE command to push it through your viewport without changing its appearance. AutoCAD will have scaled it to make this work.
measure the line you now have in model space. divide that length by the eg. 100mm you started with.
the difference in size is the scale factor. so if the new line is 5000mm, your viewport scale is 1:50
hope this helps!
Share this post
Link to post
MSasu
In Properties, below Standard scale field there is Custom scale were you have a number; that is the scale ratio which you can use to calculate the report.
For metric, divide 1 with that ratio; example:
ratio = 0.5 --> 1 / 0.5 = 2 --> 1:2 scale
For imperial, multiply 12 with said ratio; example:
ratio = 0.5 --> 12 * 0.5 = 6 --> 6":1'-0" scale
Edited by MSasu
Share this post
Link to post
Dadgad
Welcome to CADTutor. :)
After custom scale, I suspect there will be a number, which represents the scale.
If you look at the image you will see my quick properties palette reporting that
the custom scale is .025, meaning 25/1000s, or 1/40th. Viewport scale equals 40.
I have never used LT, but I imagine your display is not terribly different.
You can also check in PROPERTIES, instead of in Quick Properties.
Mircea and Stuart to the rescue, good job guys! :beer:
Edited by Dadgad
Share this post
Link to post
blowther
Amazing, thank you all so much!
I really like that workaround designerstuart, creative :)
And thanks for the welcome to the forums Dadgad.
Share this post
Link to post
Dadgad
hope this helps!
I didn't notice this earlier, but that is another interesting way to go, and if you are watching your commandline, after you use the changespace command,
the commandline will report the scaling which took place. Or you can just hit F2,
and check in your commandline history to see the scaling report. :beer:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
