vernonlee Posted July 28, 2014 Share Posted July 28, 2014 (edited) Hi guys, In my work, I am tasked to locate & adjust dimension as some objects (lines/polylines.blocks etc...) has shifted/moved. I get an earful from my boss for missing out some of it. The problem is some of the changes are only a few mm & had to zoom in extremely close to see that the dimension leader is eg, 5mm away from the object. I can't possible zoom in to every one of them. So i am asking for help on a LISP to help to highlight these dimensions where the object it has snap to is shifted. Thanks Edited July 28, 2014 by vernonlee Quote Link to comment Share on other sites More sharing options...
Tharwat Posted July 28, 2014 Share Posted July 28, 2014 Welcome to CADTutor . Your explanations is not that clear at least to me , so try to give more details or an example that is clear to get what you are after . Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 28, 2014 Share Posted July 28, 2014 Are the objects in Model space and the dims in a layout ? I am having trouble unlocking the dim from object, I am pretty sure there is a variable about attaching DIM or letting it float can not remember it. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 28, 2014 Share Posted July 28, 2014 Welcome to CADTutor. Turn on your ANNOMONITOR, as described in the screen shot from the SYSVDLG description, to one of the 2 highlighted values, 2 is probably best in your case. In 2013 the default setting was changed to 1, previously the default OOTB had been set to 0. Quote Link to comment Share on other sites More sharing options...
vernonlee Posted July 28, 2014 Author Share Posted July 28, 2014 Are the objects in Model space and the dims in a layout ? I am having trouble unlocking the dim from object, I am pretty sure there is a variable about attaching DIM or letting it float can not remember it. Yes. That is correct. Object in model. Dimension in layout Quote Link to comment Share on other sites More sharing options...
vernonlee Posted July 28, 2014 Author Share Posted July 28, 2014 Welcome to CADTutor. Turn on your ANNOMONITOR, as described in the screen shot from the SYSVDLG description, to one of the 2 highlighted values, 2 is probably best in your case. In 2013 the default setting was changed to 1, previously the default OOTB had been set to 0. Hi. Are you answering my question? I do not understand what you mean. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 28, 2014 Share Posted July 28, 2014 vernonlee: Do you make use of annotative dimensioning? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 28, 2014 Share Posted July 28, 2014 Type ANNOMONITOR at the commandline, hit ENTER. A number will be displayed at the commandline, which indicates the current setting of the ANNOMONITOR system variable. Enter 2, then hit ENTER. Open one of those drawings, there will likely be numerous new icons displayed. Each one, an exclamation point inside a triangle, indicates a dimension which has become disassociated from the geometry which it is meant to measure. A very timely question by ReMark, and a good one at that! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 28, 2014 Share Posted July 28, 2014 Thanks Dadgad knew there was something, vernonlee me personally I stay away from model/layout and DIM only in model to me a good reason to do it that way, get ready for the other opinions there will be a lot only I know the head aches I have to fix up. Dadgad may be on the money. To fix wow ??? Do some checking as per the suggestion. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 28, 2014 Share Posted July 28, 2014 When done with some forethought and correctly (dimensions = associative) there is no problem dimensioning in a layout. But I am NOT saying that is the only way it should be done or the best way. It is up to the individual company or user to find the method that works best for their situation. Quote Link to comment Share on other sites More sharing options...
vernonlee Posted July 28, 2014 Author Share Posted July 28, 2014 vernonlee: Do you make use of annotative dimensioning? Hi. I am not sure actually. This drawings are not done by me. Quote Link to comment Share on other sites More sharing options...
vernonlee Posted July 28, 2014 Author Share Posted July 28, 2014 Type ANNOMONITOR at the commandline,hit ENTER. A number will be displayed at the commandline, which indicates the current setting of the ANNOMONITOR system variable. Enter 2, then hit ENTER. Open one of those drawings, there will likely be numerous new icons displayed. Each one, an exclamation point inside a triangle, indicates a dimension which has become disassociated from the geometry which it is meant to measure. A very timely question by ReMark, and a good one at that! Will this work for dimensions annotative & non annotative? I will also try it when I am back in the office tomorrow. Thanks again. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 28, 2014 Share Posted July 28, 2014 (edited) Found this at the AutoDesk website. "The Annotation Monitor flags non-associative annotations with a yellow exclamation marker and a red plus (+) icon appears in the drawing status bar. I've listed the sysvar details from the help file below. You may want to take a look at the AutoCAD Help for more details but briefly put, the Annotation Monitor works on Dimension Objects including Leaders and MLeaders." Edited July 28, 2014 by ReMark Quote Link to comment Share on other sites More sharing options...
vernonlee Posted July 29, 2014 Author Share Posted July 29, 2014 Type ANNOMONITOR at the commandline,hit ENTER. A number will be displayed at the commandline, which indicates the current setting of the ANNOMONITOR system variable. Enter 2, then hit ENTER. Open one of those drawings, there will likely be numerous new icons displayed. Each one, an exclamation point inside a triangle, indicates a dimension which has become disassociated from the geometry which it is meant to measure. A very timely question by ReMark, and a good one at that! Hi Dadgad, I change to 2 as suggested. Unfortunately All The dimension are with exclamation mark. Even the ones that are correct(meaning I can see the dimension leader is snap on to the object/line/polyline) In this case, what other alternatives do I have? Will a lisp work? Thanks. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 29, 2014 Share Posted July 29, 2014 So, what that tells us is that ALL of the dimensions in the drawing are NON-Associative. Too bad, because if they were associative, it would have flagged ONLY those which had become disassociated from those entities which they were meant to describe, and would thus require your ministrations. I have looked through the dimstyle manager help, and I don't see any way to change existing non-associative dimensions to associative dimensions. The MATCHPROP command will copy annotative properties, if dimensions has been selected in the SPECIAL PROPERTIES dialog for the command, and confer annotativity to a previously non-annotative dimension. I don't know enough about lisp to be able to tell you whether or not a lisp based solution could be created. I am inclined to think it probably could, but that is just conjecture on my part. Should you wind up, as I suspect having to fix all of these one at a time, don't run too many O Snaps. I would suggest just using Endpoint, Quadrant, Center & Midpoint. The less you need, the better, as it will facilitate your quickly getting them where they are meant to be, without missed picks. Good luck, maybe somebody else knows a way, or can suggest a lisp solution, sorry the dimensions turned out to be non-associative, scuttling my initial approach to your problem. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 29, 2014 Share Posted July 29, 2014 (edited) No code but I would Chspace all the dims hopefully this will not cause to many dimscale problems then at least your working in one world not two, you could then via lisp pick a dim get its node pt and look within a box for a object getting its end point and then resetting the dim node to this pt which is what you want. I think the message here is set it up right first go and advise everyone why it must be done this way. There are some other posts here at Cadtutor about layout/model and dims it would be worthwhile trying to find them as they will have some good advice about the correct method to use. I am sure Remark will find a couple for you. Edited July 29, 2014 by BIGAL Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 29, 2014 Share Posted July 29, 2014 A bit extra pick a dim the Reassociate command will do it, but still needs work just need to find node co-ords looking now. ; this is an example of how to fix 1 dim (setq pt1 (getpoint)) ; this would be replaced by the find end pt routine (setq pt2 (getpoint)); this would be replaced by the find end pt routine (setq obj (entsel "\npick dim")) ; again replace with loop of dims ; now for magic (command "dimreassociate" obj "" pt1 pt2) ; all done for 1 Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 29, 2014 Share Posted July 29, 2014 A bit extra pick a dim the Reassociate command will do it, but still needs work just need to find node co-ords looking now. ; this is an example of how to fix 1 dim (setq pt1 (getpoint)) ; this would be replaced by the find end pt routine (setq pt2 (getpoint)); this would be replaced by the find end pt routine (setq obj (entsel "\npick dim")) ; again replace with loop of dims ; now for magic (command "dimreassociate" obj "" pt1 pt2) ; all done for 1 [ATTACH=CONFIG]50109[/ATTACH] BIGAL, I remembered that you had posted previously about a dim reassociation technique, and I went looking for it OOTB earlier, but came up empty, now I know why, glad you are on the case. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 29, 2014 Share Posted July 29, 2014 (edited) Thanks Dadgad, still need node pts its buried a bit deeper inside a DIM. Should have looked at plain lisp assoc 13 &14. Edited July 30, 2014 by BIGAL Quote Link to comment Share on other sites More sharing options...
vernonlee Posted July 30, 2014 Author Share Posted July 30, 2014 So, what that tells us is that ALL of the dimensions in the drawing are NON-Associative.Too bad, because if they were associative, it would have flagged ONLY those which had become disassociated from those entities which they were meant to describe, and would thus require your ministrations. I have looked through the dimstyle manager help, and I don't see any way to change existing non-associative dimensions to associative dimensions. The MATCHPROP command will copy annotative properties, if dimensions has been selected in the SPECIAL PROPERTIES dialog for the command, and confer annotativity to a previously non-annotative dimension. I don't know enough about lisp to be able to tell you whether or not a lisp based solution could be created. I am inclined to think it probably could, but that is just conjecture on my part. Should you wind up, as I suspect having to fix all of these one at a time, don't run too many O Snaps. I would suggest just using Endpoint, Quadrant, Center & Midpoint. The less you need, the better, as it will facilitate your quickly getting them where they are meant to be, without missed picks. Good luck, maybe somebody else knows a way, or can suggest a lisp solution, sorry the dimensions turned out to be non-associative, scuttling my initial approach to your problem. Roger. Thanks for your big help. Could you clarify this sentence:- "Should you wind up, as I suspect having to fix all of these one at a time, don't run too many O Snaps. I would suggest just using Endpoint, Quadrant, Center & Midpoint. The less you need, the better, as it will facilitate your quickly getting them where they are meant to be, without missed picks." How will it facilitate ne quickly getting them where they are meant to be? Thanks Quote Link to comment Share on other sites More sharing options...
