BlackBox Posted September 22, 2014 Share Posted September 22, 2014 There is a company in Ohio that markets a product for developers that allows add ons to run in LT. It's called LTX, but it would appear that it is quite legal as it doesn't extend the functionality of LT or unlock any hidden features and is only available to serious developers. Check out the link: http://www.manusoft.com/software/ltx.html Man, what does Owen _not_ do? Not sure if it was voluntary or not, but it appears that AutoCAD LT 2013 is the latest supported version listed under "Platforms." Cheers Quote Link to comment Share on other sites More sharing options...
Tyke Posted September 22, 2014 Share Posted September 22, 2014 Not sure if it was voluntary or not, but it appears that AutoCAD LT 2013 is the latest supported version listed under "Platforms." No that is not correct. I do some work with a software company here that uses LTX with their software for use in LT and I have seen their documentation for the 2014 release of their software and it definitely supports AutoCAD LT 2015. Owen has far too many other things to do than keep his website up to date . Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 22, 2014 Share Posted September 22, 2014 No that is not correct. I do some work with a software company here that uses LTX with their software for use in LT and I have seen their documentation for the 2014 release of their software and it definitely supports AutoCAD LT 2015. Owen has far too many other things to do than keep his website up to date . No worries; thanks for clarifying. Quote Link to comment Share on other sites More sharing options...
Tyke Posted September 22, 2014 Share Posted September 22, 2014 No worries; thanks for clarifying. You're welcome. Are you going to have a go? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 23, 2014 Share Posted September 23, 2014 I know its not .Net but I updated the table in my prior post page 2 just change excel values copy the right hand column to the command line. It goes to show what can be done if we looked VBA inside excel it would be neater. LTX at $2000 cheaper to buy clones. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 23, 2014 Share Posted September 23, 2014 Are you going to have a go? Forgive my drawing a blank here ... A go at what exactly? Cheers Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 23, 2014 Share Posted September 23, 2014 LTX at $2000 cheaper to buy clones. I've never worked with any of the clones before, but at the risk of expressing a biased opinion... I happen to like BricsCAD (BCAD), as they have a good developer network (I'm a member), and a new 'major' V15 Beta just came out this month. Cheers Quote Link to comment Share on other sites More sharing options...
Tyke Posted September 23, 2014 Share Posted September 23, 2014 Forgive my drawing a blank here ... A go at what exactly? Cheers At implementing .NET in LT . If others can do it ... Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 24, 2014 Share Posted September 24, 2014 Try karelcad I had a play with using lisp etc not 100% sure but its macro recorder seemd to write .Net code. Ported lisp to Intellicad very succesfully some minor tweaks. Quote Link to comment Share on other sites More sharing options...
