You must bear with me as I'm pretty much self taught on CAD. One thing which I've never understood is the scaling of linetypes and in my new job I have to use it lots. I draw highways, so the linetypes have to be accurate. My model space is always 1:1, but when I'm plotting at say 1:500 or 1:250, the length of the lines mess up. I've solved this by changing the linetype scale to 2 for 1:500 and 4 for 1:250. I have to do this for every individual line though and I'm not even sure if it's the correct method. Can anybody advise?
Link to post
MSLTSCALE = 1
LTSCALE = 1 (some like using .5)
PSLTSCALE = 1
CANNOSCALE = (DESIRED PLOT SCALE in each viewport, set with anno scale drop down
lower right)
Link to post
Thanks for the reply rkent, but this doesn't work. I've changed everything to 1 and set cannoscale to 2:1 but the scale is still out. I've done a regenall too to make sure.
Link to post
Can you confirm that you used a metric template as the basis for your drawing? And can you also confirm that you used metric linetypes for us please? Thanks.
Link to post
I am using a metric template and linetypes - 1 unit = 1 meter.
All of the linetypes are 1 - I changed that and nothing changed. It only works if I do LTSCALE=2
Link to post
I find it curious working that ALL your layers have a Continuous Linetype, and any different linetype is set to an entity.
Also, all your linetypes seem to be custom ones, so it does not matter whether your template was metric or imperial.
Edited by eldon
you have sorted out plotting scales, so remark was unecessary
Link to post
I fail to see a problem in your drawing, in both layouts the line segments are 0.6 I don't see where you are applying different scales to the line
Link to post
I think that you want to set PSLTSCALE to 0, because the custom linetypes are drawn to the the correct length which you do not want to scale in the viewport.
Link to post
What you will have to sort out is that the plotting unit is always a millimetre, and your drawing units are metres.
I was looking at that too. The OP could set all his linetypes in the layers manager couldn't he?
Link to post
