Did the whole path, and camera and timing and all that jazz.
Camera is sticking in some areas, and not others. I tried increasing/ reducing points in the line (which is smooth..)
Why is this happening?
Also, when I try to render im getting this error:
"Error allocating mesh. Reduce the face count to render this scene.
Ah! Help!
Sounds like your computer is having trouble chewing through all the data. As far as the frame skipping/slowdown, try disabling Corner deceleration. Also try lowering the resolution or the quality and see if that improves the performance.
