Hello
Having some issue with AutoCAD 20014 scaling my view ports correctly my first metric drawing (drawn 1:1) Im try to create 1:100 scale viewport on 8"x10" paper ....
when I plot my paper space 1:1 I cant get the correct scale in the view port for 1:100 ??? what im I missing, ie... what should be my scale properties to achieve 1:100 scale in edit drawing scale menu
Ty
  • Replies 52
  • Dana W
    22
  • eloid
    16
  • ROBP
    9
  • ReMark
    2
Posted Images
Are you selecting the viewport and picking the scale to apply to the viewport? Exactly how are you applying the scale to the viewport? Can you attach the drawing to your next post here?
You shouldn't try to do metric on 8"x10" paper, it should be the appropriate size for metric which would be ~200x254. The relationship between MS and PS will never work out unless you are matching systems in both, either both imperial, or both metric (SI).
attach file, I have tried selecting the viewport frame only ....also ....just clicking within model with out panning after changing the scale
im printing my paper space 1:1
test123.dwg
Wait. I should have asked about the units. What units are you drawing in?
It will only work if your dwg units are metric :shock:
I just looked at the drawing. Your dwgunits are inches and so are your paperspace units. The viewport scales are a ratio of ONE paperspace unit = NNN modelspace units. Since the drawing is only about 8" wide, why plot at 1" = 100"? 1:3 works fine One paperspace inch = 3 modelspace inches.
new to 2014 not 100% about the units?
Then that begs the question, are you in a metric or imperial country? If you are imperial (feet & inches) then see my prior post.
Now my post #5 makes no sense at all. I should have looked at the drawing first.
I don't have 200x256 in my list for paper sizes? for this printer? hp laser
the part don't understand .... when making viewports for metric drawings..... im not clear how to edit the drawing scales for the scales I need 1:100, 1:200,1:300
I understand your point about using metric paper sizes... but still doesnt work?
are my scale properties correct? 1:3? in this drawing...
imperial drawing and scaling is more straight forward...lol
Even if i cannot open the drawing maybe this could help step by step
I followed your steps 1:25 makes the scale too small
Increase it then 1:5
are you drawing in imperial or metric?
I believe units set to decimal.... not sure how to check it 2014?... paper is metric
Dont care about the paper how big is the piece you are drawing?
20 meters cross -section which I want use 1:100 scale in my viewport
20 meters crossection
piece is drawn in imperial because scale 1:25 it should not be small especially in an 8.5x11 sheet of paper piece will not fit the viewport a that scale
