Copy attributes data block to block different layouts!
Greenuser
Hi
After several years in autocad ive never really got into lisps all that much .
However I realise I should probably make the first steps into that direction.
As such I seek assistance !!
The problem:
Ive come into a new position and they are using a basic template.
Pretty much its an A4 , A3 and A1 title block all with the same attributes on separate layouts.
Owner : xxxx
Dwg number : ZZZZZ
Etc etc
Seems a bit old school and I would like to setup a SSM or other such method for ease of use in the future. But my current problem is, would it be possible to edit the A4 block and have all layouts update accordingly ?
What is the best method to acheive this .
Cheers
  • Replies 21
  • Greenuser
    8
  • Lee Mac
    7
  • asuarez2311
    3
  • BIGAL
    2
Trivial i know but if i can do it without manually doing it that would be great and save me typing it out multiple times which is what im doing now.
Maybe i should look up how to link a title block to a spread sheet !
You can do a generic lisp that will work with any block by using the attribute creation order, then you just enter the value attribute order and the lisp finds all occurances.
The example below will update every title block in the dwg for a certain attribute.
; changes to issued for construction
: thanks to lee mac for original code
(vl-load-com)
; 1.  Get current date in mm/dd/yy format.
(defun ddmmyy (/ x today)
    (setvar "cmdecho" 0)
    (setq x (getvar "CDATE"))                 ; get current date
    (setq today ( rtos x 2 4))                    ; convert to a string
    (setq date (strcat (substr today 7 2) "."    (substr today 5 2) "." (substr today 3 2) ))
(setq oldtag1 "DRAWING_STATUS") ;attribute tag name
(setq newstr1 "ISSUED FOR CONSTRUCTION")
(setq oldtag2 "REV_NO")  ;attribute tag name
(setq newstr2 "0")
(setq ss1 (ssget "x"  '((0 . "INSERT") (2 . "DA1DRTXT"))))
(setq inc (sslength ss1))
(repeat inc
(foreach att (vlax-invoke (vlax-ename->vla-object (ssname SS1 (setq inc (1- inc)) )) 'getattributes)
(if (= oldtag1 (strcase (vla-get-tagstring att)))
(vla-put-textstring att newstr1)
) ; end if
(if (= oldtag2 (strcase (vla-get-tagstring att)))
(vla-put-textstring att newstr2)
) ; end if
) ; end for
) ;end repeat
(setq oldtag1 "REV-NO")
(setq newstr1 "0")
(ddmmyy)
(setq oldtag2 "DATE")
(setq newstr2 date)
(setq oldtag3 "AMENDMENT")
(setq newstr3 "ISSUED FOR CONSTRUCTION")
(setq ss2 (ssget "x"  '((0 . "INSERT") (2 . "REVTABLE"))))
(setq inc (sslength ss2))
(repeat inc
(foreach att (vlax-invoke (vlax-ename->vla-object (ssname ss2 (setq inc (1- inc)))) 'getattributes)
(if (= oldtag3 (strcase (vla-get-tagstring att)))
(vla-put-textstring att newstr3)
(setq ss1 nil)
; (setq ss2 nil)
Here's another example demonstrating how to synchronise attribute values between layouts:
(defun c:syncatts ( / ent enx idx lst sel )
   (while
       (progn (setvar 'errno 0) (setq ent (car (entsel "\nSelect source block: ")))
           (cond
               (   (= 7 (getvar 'errno))
                   (princ "\nMissed, try again.")
               (   (null ent) nil)
               (   (or (/= "INSERT" (cdr (assoc 0 (setq enx (entget ent)))))
                       (/= 1 (cdr (assoc 66 enx)))
                   (princ "\nSelected object is not an attributed block.")
   (if (and ent
           (setq lst (LM:getattributes ent)
                 sel (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (cons 410 (strcat "~" (getvar 'ctab)))))
       (repeat (setq idx (sslength sel))
           (LM:setattributevalues (ssname sel (setq idx (1- idx))) lst)
;; Get Attributes  -  Lee Mac
;; Returns an association list of attributes present in the supplied block.
;; blk - [ent] Block (Insert) Entity Name
;; Returns: [lst] Association list of ((<Tag> . <Value>) ... )
(defun LM:getattributes ( blk / enx )
   (if (= "ATTRIB" (cdr (assoc 0 (setq enx (entget (setq blk (entnext blk)))))))
       (cons
           (cons
               (cdr (assoc 2 enx))
               (cdr (assoc 1 enx))
           (LM:getattributes blk)
;; Set Attribute Values  -  Lee Mac
;; Sets attributes with tags found in the association list to their associated values.
;; lst - [lst] Association list of ((<tag> . <value>) ... )
;; Returns: nil
(defun LM:setattributevalues ( blk lst / enx itm )
       (if (setq itm (assoc (cdr (assoc 2 enx)) lst))
               (if (entmod (subst (cons 1 (cdr itm)) (assoc 1 enx) enx))
                   (entupd blk)
               (LM:setattributevalues blk lst)
The above program uses functions from my Attribute Functions library.
The code will currently iterate over all attributed blocks residing in layouts other than the current layout, and will populate all attributes with tags matching those found in the selected source block; the program could therefore be made more efficient by including a block name filter in the ssget filter list, however, I was not aware of the block names you were using and so left it generic.
Lee
Edited by Lee Mac
i find this post useful and Lee's code worked
however, if i have two attributed tags, the one is blank and the other one has a value, it fills in both tags
Do both attributes have the same tag name within the block?
yes Lee.
I edit my block and change its tag names.
its working fine now.
thanks a lot! this will be very useful
You're welcome!
For future reference, I would always strongly advise against the practice of using duplicate attribute tags, since the attribute tag is used to differentiate between the attributes held by a block - with duplicate attribute tags, any program must rely only on the order in which the attributes are encountered within the block.
Lee
thanks guysSo far ive run Lee's code and Its ask to select block . I select my A4 template (contains the values i want to duplicate)
Command:
ATTSYNC
Enter an option [?/Name/Select]
Select a block:
ATTSYNC block A4 Template 23-6-08? [Yes/No] :
ATTSYNC complete.
The lsp breaksdown at this point returns :
ATTSYNC complete.
Lee
Thanks to part one of your lsp i hit "?" and got the full list
A4 Template 23-6-08, A3 Template 23-6-08, A1 Template 23-6-08, On-site design template 26-6-08
ill do some homework on this during the day i appreciate it! see if i cant figure it out, i hold some hope !
Regards
Greenuser
Its all there just need to switch language mode from plain english to programming which im far from fluent in but we must start somewhere!
Had a browse on lee mac nice site! Seems Lee is god in these parts appreciate the responses!
Also thanks bigal was aware of find and replace and its still more typing intensive then i would like.
Ideally Id like to type once and if ive used the wrong template i would appreciate not having to duplicate my typing efforts :P
One saving grace with the find function is it remembers the find and replace values saving having to type them out again which is nice as the text is pre filled for now!
Command:
ATTSYNC
Select a block:
ATTSYNC complete.
ATTSYNC complete.
Lee
Regards
Greenuser
The command for my code is syncatts, not attsync (this is a standard command).
Thank for your time Lee.
I was browsing your site and found numerous oppoutunities to become more efficient!
Ill be sure to find some begginer threads in an attempt to improve my lisp knowledge!
  • 8 years later...
1 hour ago, asuarez2311 said:
Hello Lee, it is possible to syncatts of blocks from a specifics (selected) layouts?
From specific layouts or to specific layouts? Currently the user is selecting a single block and attributes are synchronised to all other blocks in other layouts which possess the same attribute tags; are you looking to target specific layouts?
