Hey everyone ... I need some help and I have noooo idea where to start or how to write the code needed to do my thought. I need a text file that gives a marker when you open and close a drawing w/ a time stamp and so i can track my day w/o trying to figure out how many hours I worked on a drawing. This has to be a continuous list for the day. There was a previous post from 2010 which worked great but it put an individual text file in each drawing location. I need one text file so i can see all the drawings that were opened and closed w/ the time & date..... So any help would be much appreciated
Joey G
Link to post
  • Replies 31
  • JoeyG_77
    15
  • Commandobill
    10
  • BIGAL
    3
  • tzframpton
    2
I have no idea where to even begin ... This is the code i received from the forum
(defun TimeReac nil
(vl-load-com)
(if (not (vl-position "TIMEREACT"
(mapcar (function strcase)
(mapcar (function vlr-data)
(mapcar (function cadr)
(vlr-reactors :vlr-command-reactor))))))
(vlr-command-reactor "TIMEREACT"
(list
(cons :vlr-commandWillStart 'GetTime_C)
(cons :vlr-commandEnded 'GetTime_O)))
(princ "\n<< Reactor Initiated >>"))
(princ "\n<< Reactor Already Running >>"))
(princ))
(TimeReac)
(defun GetTime_O (Reactor Args)
(if (eq "OPEN" (strcase (car Args)))
(GetTime))
(princ))
(defun GetTime_C (Reactor Args)
(if (eq "CLOSE" (strcase (car Args)))
(GetTime))
(princ))
(defun GetTime (/ toDate *error* ofile)
(defun toDate (var format)
(menucmd (strcat "m=$(edtime,$(getvar," var ")," format ")")))
(defun *error* (msg)
(and ofile (close file))
(princ (strcat "\n** Error: " msg " **")))
(princ))
(if (setq ofile (open (strcat (getvar 'DWGPREFIX) (getvar 'DWGNAME) "_log.txt") "a"))
(write-line (strcat "DATE: " (toDate "DATE" "DD.MO.YY HH.MM.SS")) ofile)
(write-line (strcat "DRAWING: " (getvar 'DWGPREFIX) (getvar 'DWGNAME)) ofile)
(write-line (strcat "CREATED: " (toDate "TDCREATE" "DD.MO.YY HH.MM.SS")) ofile)
(write-line (strcat "TOTAL EDITING TIME: " (toDate "TDINDWG" "HH.MM.SS") "\n") ofile)
(setq ofile (close ofile))))
(princ))
(defun c:TimeOFF (/ Reac)
(vl-load-com)
(if (and (setq Reac
(car
(vl-remove-if-not
(function
(lambda (x)
(eq "TIMEREACT" (strcase (vlr-data x)))))
(vlr-added-p Reac))
(vlr-remove Reac)
(princ "\n<< Reactor Deactivated >>"))
(princ "\n** Reactor Not Running **"))
(princ))
Link to post
Commandobill
Ok, the line you want to change is this one:
If you let me know the exact location and file name I can change it for you. Otherwise, you would change :
to something like :
(setq ofile (open "C:\\somefilename.txt" "a"))
The double backslash is key.
Link to post
C:\Users\Acad2015\TimeLog\Logfile.txt
also would this create a new file everyday .. its a silly question but still wanted to ask =)
Link to post
Commandobill
Here's the new code:
;;I believe this was originally written by Lee-Mac
;;Date: Unknown
;;Modified By:Commandobill
;;Date 04/21/15
;;Reason for change: Updated to make text file be in a static position instead of dynamic.
(defun TimeReac nil
(vl-load-com)
(list
(princ))
(TimeReac)
(GetTime))
(princ))
(GetTime))
(princ))
(princ))
(if (setq ofile (open "C:\\Users\\Acad2015\\TimeLog\\Logfile.txt" "a"));;Location of change
(princ))
(vl-load-com)
(if (and (setq Reac
(car
(vl-remove-if-not
(function
(lambda (x)
(vlr-added-p Reac))
(vlr-remove Reac)
(princ))
We could always change the code to create a new text file each day, but currently it does not.
Link to post
This is the text from the file it gives
DATE: 04.21.15 13.05.26
DRAWING: X:\Churchill\Engineering\JohnsBedroom\ChurchHill_JohnsBedroom_Rev0.dwg
CREATED: 04.17.15 12.35.19
TOTAL EDITING TIME: 03.03.43
Bill is there a way to catch the action such as like ..
ACTION:OPEN
ACTION:CLOSED
Edited by JoeyG_77
MisTyped info
Link to post
Commandobill
I'm sure there us a much more elegant way of doing this...
;;Author: Lee-Mac
;;Date: 01/27/10
;;Date 04/21/15
(defun TimeReac nil
 (vl-load-com)
(list
 (princ))
(TimeReac)
   (GetTime))
 (princ))
   (GetTime))
 (princ))
   (princ))
 (if (setq ofile (open "C:\\Logfile.txt" "a"));;Location of change
(write-line "ACTION: CLOSED" ofile)
(write-line "ACTION: OPENED" ofile))
 (princ))
 (vl-load-com)
 (if (and (setq Reac
	  (car
	    (vl-remove-if-not
	      (function
		(lambda (x)
   (vlr-added-p Reac))
     (vlr-remove Reac)
 (princ))
Link to post
Commandobill
Lol, sorry Bill. Just giving an alternative resource is all.
Ha! I was just messing with you. I'm sure it's a good program.
Link to post
Bob This is perfect !!! BUT !!! ... is there a way to add a space between each grouping =) This is the code I have .. Made some tweaks
;;Author: Lee-Mac
;;Date: 01/27/10
;;Date 04/21/15
(defun TimeReac nil
(vl-load-com)
(list
(princ))
(TimeReac)
(GetTime))
(princ))
(GetTime))
(princ))
(princ))
(write-line (strcat "DATE: " (toDate "DATE" "MO.DD.YY ** HH.MM.SS")) ofile)
(princ))
(vl-load-com)
(if (and (setq Reac
(car
(vl-remove-if-not
(function
(lambda (x)
(vlr-added-p Reac))
(vlr-remove Reac)
(princ))
Edited by JoeyG_77
WRONG CODE !! .... SORRY BILL
Link to post
This is the file I am getting ... Now
ACTION: OPENED
DATE: 04.21.15 15.22.02
DRAWING: X:\Churchill\Engineering\MasterBedroom208\ChurchHill_MasterBedroom208_Rev0.dwg
ACTION: OPENED
ACTION: OPENED
DATE: 04.21.15 TI4E 15.25.45
DRAWING: X:\Holliday 2\Engineering\Parlor\Holliday_Parlor_Rev0.dwg
ACTION: OPENED
DATE: 04.21.15 ** 15.26.43
DRAWING: X:\Holliday 2\Engineering\Parlor\Holliday_Parlor_SM.dwg
Is there a way to get it to look like this below ....
ACTION: OPENED
ACTION: OPENED
ACTION: OPENED
Link to post
I have everything I need .... but i just need it to separate it in the log !! ..... its gotta be easy but i just dont know what is missing .
Link to post
Commandobill
I forgot to add the "\n" for new line in the code. My bad.
;;Author: Lee-Mac
;;Date: 01/27/10
;;Date 04/21/15
(defun TimeReac nil
(vl-load-com)
(list
(princ))
(TimeReac)
(GetTime))
(princ))
(GetTime))
(princ))
(princ))
(write-line (strcat "DRAWING: " (getvar 'DWGPREFIX) (getvar 'DWGNAME) "\n") ofile)
(princ))
(vl-load-com)
(if (and (setq Reac
(car
(vl-remove-if-not
(function
(lambda (x)
(vlr-added-p Reac))
(vlr-remove Reac)
(princ))
Link to post
Bill you are a rockstar !!! ... This is perfect is there any way to add a variable that will change the date daily ... so there would be a list of logs for the week so during that day it will write to the same file and then the next it would do the same to that days date ..
(if (setq ofile (open "C:\\Users\\Acad2015\\TimeLog\\Logfile-[color="red"][b]DATEVARIBLE[/b][/color].txt" "a"));;Location of change
Link to post
