I currently using macro script to facilitate quicker printing.
eg,
^C^C-plot;Y;;DWG To PDF.pc3;ISO full bleed A0 (841.00 x 1189.00 MM);m;Landscape;N;W;\\1=1;C;Y;SIACAD_rev.ctb;Y;N;N;N;;Y;Y;
The above works fine.
However I cannot get this plotter name to work: "\\PLOTSTN2\hp500ps"
It is due to the \
I also tried "//PLOTSTN2/hp500ps" but it still do not work.
Any advise?
  • Replies 26
  • vernonlee
    16
  • BIGAL
    8
  • ReMark
    1
  • YZ
    1
Have to wait till I get back to work but look at my posts about autopilot they have \\stuff in them and they work as we plot to server plotters.
Sorry on iPad and on holidays at moment so don't have true code but all my autoplot routines use a \\ server name will be back Friday my time, others may post.
no problem. Enjoy your holidays. :)
Await your return :P
I use a lisp so maybe rewrite the macro as if its a lisp you can have lisp in menu's etc.
^c^c(COMMAND "-PLOT" "Y" "" "\\\\PROD\\100xxxxx-PRN03" etc etc)
Don't quite get what you mean.
Is LISP a requirement to get server plotter yo work in my case?
Or do you mean to draft the macro script like as if it was a LISP to get the server plotter to work? But it is still a single script. Do meaning just put a open bracket & close bracket at the end is my script commend will do?
Yes just add the brackets change ; to space, any returns \ must now be ""
(COMMAND "-PLOT" "Y" "" "\\\\PRN03\\100B-PRN03" "A3 (297 x 420 mm)" "m" "LANDSCAPE" "N" "W" "-6,-6" "807,560"
  "1=2" "C" "y" "DesignlaserCOLOUR.ctb" "Y" "n" "n" "n" "N" "N" "y")
So you have a macro that works for one plot driver.
And when you edit that macro to this driver: //PLOTSTN2/hp500ps
exactly what happens?
When i run this
^C^C-plot;Y;;//PLOTSTN2/hp500ps;ISO A0;m;Landscape;N;W;\\1=1;C;Y;RS485-URA A0 COLORED.ctb;Y;N;N;N;;Y;Y;
i get this
Command: -plot
Detailed plot configuration? [Yes/No] : Y
Enter a layout name or [?] :
Enter an output device name or [?] : //PLOTSTN2/hp500ps
/PLOTSTN2/hp500ps> not found.
Enter an output device name or [?] : ISO A0
not found.
Enter an output device name or [?] : m
not found.
Enter an output device name or [?] : Landscape
not found.
Enter an output device name or [?] : N
not found.
Enter an output device name or [?] : W
not found.
Not sure what is wrong but tried this 2 variation but could not plot
code 1
(COMMAND "-plot" "Y"  "\\PLOTSTN2\hp500ps" "ISO A0" "m" "Portrait" "N" "W" "\\" 1=1 "C" "Y" "RS485-URA A0 COLORED.ctb" "Y" "N" "N" "N"  "Y" "Y")
I got this (the command just stop there)
Command: (COMMAND "-plot" "Y" "
code 2
(COMMAND "-plot" "Y"  "\\\\PLOTSTN2\\hp500ps" "ISO A0" "m" "Portrait" "N" "W" "\\" 1=1 "C" "Y" "RS485-URA A0 COLORED.ctb" "Y" "N" "N" "N"  "Y" "Y")
Where did I went wrong?
Not sure about this "\\" check for yes no etc
That is for allowing me to click the window area. Is that what is causing the problem? How should I write it?
AutoCAD 2015. You can't create this macro using the Action Recorder?
Just add the two lines at start after the defun line and replace the \\n with p1 p2
(setq p1 (getpoint "\nPick bottom left"))
(setq p2 (getpoint "\nPick top right"))
Tried it. The Action Recorder cannot preselect the plot configurations. It will play up to the plot setup & stop there for you to manually select.
To reduce complications, I base on the extend method but i still get the same error
(COMMAND "-plot" "Y"  "\\\\PLOTSTN2\\hp500ps" "ISO A0 " "m" "LANDSCAPE" "N" "E" "1:1" "C" "Y" "RS485-URA A0 COLORED.ctb" "Y" "N" "N" "N"  "Y" "Y")
(COMMAND "-plot" "Y"  "\\PLOTSTN2\hp500ps" "ISO A0 " "m" "LANDSCAPE" "N" "E" "1:1" "C" "Y" "RS485-URA A0 COLORED.ctb" "Y" "N" "N" "N"  "Y" "Y")
I get this
it seems to be stopping at my plotter device.
Maybe a typo look at this carefully the extra space "ISO A0 "
